The iBasso D12, dual dacs . images . new Sysconcept optical cable . . Topkit by HiFlight. .
Sep 25, 2010 at 12:13 PM Post #47 of 606
http://www.ibasso.com/en/products/show.asp?ID=63
i got it correct. do i get a compliment unit?
D12 - Anaconda
Sep 25, 2010 at 12:28 PM Post #49 of 606
I really like the look of the D12.  The distressed aluminum effect is purty.  If it sounds as good as the D10, I'm going to have to get one.
Unfortunately I can't afford it until November 1st.  But they'll probably be be low supply until then anyway.  So I'll just add it to the wishlist.
(BTW, Is anyone planning to bring a D12 to RMAF in Denver?)
Sep 25, 2010 at 3:59 PM Post #54 of 606
They have described the dac as sounding every bit as good as the D4, which is excellent for a dac. With improvements to the amp section, I imagine for IEM's and a number of phones, using this optical, USB or coax should be a very good listen. The number of opamps now that can be used being single and double also really opens up the field.
Sep 25, 2010 at 10:22 PM Post #58 of 606
That is true. The D12 with coax and optical input will put it up one notch. I look forward to impressions. I have a feeling it will be a long lived combination dac/amp.
Sep 26, 2010 at 12:04 AM Post #60 of 606
I would think the voltage would be too low for them to work correctly. They can take, relative to the 5 volt systems of late, a lot more DC.
