kalibri
Gotcha. No I do not believe it does that.Well I mean if I play an audiobook to 2 hours. Then go listen to an album. If when I go back to that audiobook it will start at 2 hours wher eI left off.
I don't use Macs outside work but get a large enough SD card (I use a 512GB personally) and rsync (warning, Terminal required so not for the faint of heart) all the music you have. The rsync again when you add new music.What is your favorite way to manage music libraries on Mac with an SD card?
Syncthing has been working well for me. I used to have the Android app run on a Hiby R5 directly. Now I just use the Windows application(Syncthing also supports Mac) pointing to the SD card drive letter. As soon as I plug the card in, the application will start syncing my library with it.What is your favorite way to manage music libraries on Mac with an SD card?
There is a bubble on my factory applied screen protector. I do like the red color. Build quality is very nice in my opinion.Anyone have Hiby R3 II in RED color and can share pictures? Thanks
Mine had a little bubble in the factory screen protector too. Just a small one, it's still there.There is a bubble on my factory applied screen protector. I do like the red color. Build quality is very nice in my opinion.
There's a setting for this. The last toggle in the setting menu from the Music interface. I never thought about not going into the artwork view but I actually quite like it.What's up with the UI of this thing? When I play a track it just sits at the track listing on the album, doesn't go into an album artwork view that shows the track position and what not.
It has more power. This SHOULD increase dynamics, but would depend on the power needs of your iems. In my experience, the 4.4 does sound better.In your opinion. Some swear 4.4 "sounds better" but it never has to me. I'd be willling to bet they (you) wouldn't be able to tell any difference, consistently, in a blind A/B either. I'm more than happy with the sound and power out of the 3.5 thanks.
Not sure it’ll help much: I am on Windows PC and had zero problem copying directly to the R3-II (make sure it is in “storage” mode in the settings), and had no issue through WiFi either (the R3-II starts an FTP-like server)…Got a R3 II in for a demo for a couple of weeks, so far I really like the sound this little player puts out!
AirPlay has worked ok, although it was rather flakey when on my home WiFi. Hotspotting the R3 II to the phone seems to have no issue. Sometimes the artwork doesn't display properly on the R3 II, no idea why it would be inconsistent, but I could live with that as I'm controlling playback from the phone anyway.
File management on an SD card has been a real PITA tho I have to say.
First thing I did was pop my 400Gb card out of my SR25 and into the R3 II. Did a scan, let it run for a few minutes, and all was good.
Problems started when I wanted to try adding more to the card. I'm used to Android File Transfer from my Mac to either SR25 or my RS6, but that obviously won't work with the R3 II. The Mac still recognises R3 II as a USB device when I plug it in, but I see no folders/files or anything.
So I tried wireless, and browsed to the IP provided by the R3 II. Took ages for anything to come up, but when it did, I saw nothing, as in, none of the folders/files that were on the card. Putting the card back into the SR25 confirmed that the R3 II wiped the card. w.tf?
I then used Android File Transfer to copy a few folders/files back onto the card, popped it back into the R3 II, scanned, and voila, music again. All good.
BUT now this morning I go to use the R3 II and it can't find any music. Scan finds 0 files. W.TF again??
Seems like there are some magic tricks I'm not aware of to get music copied to and indexed onto an SD Card for this player, would appreciate some insight, thanks!
