The FiiO X1 Discussion and Help and Support Thread |192K/24B|100mW | LO | inline remote
May 31, 2014 at 4:48 AM Post #1,038 of 7,791
BillsonChang007
Johor, Malaysia
It's a low cost all plastic player... they will probably be paired with poor quality earbuds.
A bassy player should sound very very dark with cheap buds.
I don't think FiiO mentioned that it will all be made of plastic. What makes everyone think so though? @.@ Apple iPod Nano are colorful too but they are no plastic.
May 31, 2014 at 5:03 AM Post #1,040 of 7,791
Silverprout
not ETA, but we will have some engineer samples in this month
in this month
Jun 2, 2014 at 2:29 AM Post #1,045 of 7,791
CH23
Does the external material choice in any way affect the audio fidelity of the device?
(This is a rhetorical question)
Jun 2, 2014 at 3:07 AM Post #1,046 of 7,791
Taveren
MB Canada
The external material is really really important as depending on the material resonance, the amount of decibel increase will vary. Plus the jitter is eliminated and thereby produce enhanced soundwave production not to mention the thermal reflectance of the material will contribute to the amount of cosmic radiation entering the dac portion causing sonic imbalance. Thereby the best material to use for daps is the highly recommended unobtainium. :grin:
Jun 4, 2014 at 6:11 PM Post #1,048 of 7,791
ILoveGrado
What chip do you guys think Fiio will use for the amp section for this X1? Looking at history, Fiio normally uses similar chip from their other product line, e.g. OPA1612+ dual LMH6643 in their Kunlun for their X5, and AD8397 from their E11 for their X3. If I have to guess, they probably are going to use the op amp in their budget amp like E6, which is a TPA6130a (127 mW to 16 ohm)
Jun 4, 2014 at 6:19 PM Post #1,049 of 7,791
Saoshyant
Lenexa, KS
It seems it should match up with the power of the e6. I am kind of hoping we get surprised and its a better chip, something that'll help fill out the sound slightly better.
Jun 4, 2014 at 6:34 PM Post #1,050 of 7,791
ILoveGrado
That is what I am hoping as well. All my favorite amp like RA1 and O2 uses NJM4556A, that is my wish to James Fiio.
