The FiiO X1 Discussion and Help and Support Thread |192K/24B|100mW | LO | inline remote
post-13155189
Post #7,681 of 7,791
pedronet
Portugal
Portugal
  My first generation Fii0 x1 no longer will mount on my computer desktop (Mac). I've tried different usb cables, restarted the computer, removed and put back the memory card and tried disk utility all to no avail. This has never happened before. Amy suggestions?
Thanks!
I know this will sound stupid but try a different port. Each port has a different driver (well actually the same but it's seen as a different device). If something happened to the driver that was bridging the X1 and the PC, this should fix it.
post-13155241
Post #7,682 of 7,791
JWolf
Or try another computer in case something's up with that one.
post-13156593
Post #7,683 of 7,791
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Thanks!
Dear Jeffrey Davis,
You may try to change another USB ports and TF cards to see whether it helps?
If you have another computers, does this issue happens as well?
Best regards
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
post-13161160
Post #7,684 of 7,791
Eric321
My brother purchased a new Acer PC which has 3 USB 3.0 ports. Using these ports, will charging my FiiO X1 go even faster compared to my old 2007 HP Pavilion PC? Thanks in advance!
post-13166327
Post #7,685 of 7,791
DGonlag2
Hard to say. USB3.0 does have more pins which allows for more current to pass through. But i think it really depends on the implementation.
You can probably charge a bit faster though.
post-13180564
Post #7,686 of 7,791
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
Bucharest, Romania
Age
25
Website
audiophile-heaven.com
Hello!
IS the designer for X1 custom FW still around this thread?
post-13184455
Post #7,687 of 7,791
berkaytas
Hello everyone,
I bought a Fiio X1 DAP 2-3 months ago from amazon, in USA and opened the box last night. It was not working at first so i thought the battery could be empty. I plugged it into my computer and then it started working. I left it to charge up for 2 hours and in its manual, it says that the charging takes 3 hours. So, when i came back to check it after 2 hours, i found that the battery of the X1 is swollen and completely bloated, the back side of the player is disconnected (like dislocated) because of the battery. I quickly unplugged from the computer and now, the device is not working. I am currently in Turkey and not going back to USA. What do you think i should do? Any help would be highly appreciated. Thanks in advance.
post-13184518
Post #7,688 of 7,791
JamesFiiO
Sponsor: FiiO
  Hello everyone,
please contact our support team by support@fiio.net and our staff will help you .
post-13184706
Post #7,689 of 7,791
berkaytas
I already sent an e mail approximately 5-6 hours ago to that e mail address. Thanks for the quick reply.
post-13187302
Post #7,690 of 7,791
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Dear berkaytas,
We have received the mail you sent. Please check our reply from your mailbox. Sorry for bringing inconvenience to you.
Best regards
post-13265967
Post #7,692 of 7,791
ggeinec
Since I upgraded my gen 1 X1 to firmware 2.0 scrolling with the wheel is awful. As I scroll sometimes the selection doesn't move at all, sometimes the selection gets stuck between two adjacent songs and jumps back and forth between them, sometimes the selection moves forward then jumps back a few songs, moves forward again then jumps back a few songs again and repeats. Slowing way down with the scrolling helps a bit but that isn't a realistic option. This is extremely frustrating. Is there a setting I have missed to fix this or will I have to roll back to the previous firmware? Thanks!
post-13266812
Post #7,693 of 7,791
Yes there is a setting.
System Settings > Scroll Wheel Press Function > Set to off
post-13267004
Post #7,694 of 7,791
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
Dear ggeinec,
If you are using FW2.0, but the cursor jumps up and down still. It may be hardware issue with your X1.
Best regards
post-13271361
Post #7,695 of 7,791
ggeinec
Thanks for that information.
Unfortunately I don't see that setting in FW 2.0. I think I will roll back to 1.6 since for my X1 the scrolling was much better with that one.
