The FiiO X1 Discussion and Help and Support Thread |192K/24B|100mW | LO | inline remote
Discussion in 'Portable Source Gear' started by jamesfiio, Nov 20, 2013.
132 133 134 135 136 137 138 139 140 141
143 144 145 146 147 148 149 150 151 152
  1. Cotnijoe
    Width wise, id say its only a little behind the DX90 width, which i dont find particularly huge either. Ill double check again. Havent listened to the DX90 in a while
  2. twister6 Contributor
    I find it to be average, a bit less than X5.  But it's easily fixable by switching to LO and adding E11k or E12.  If you want to blow your mind with 3D staging, step up to C5.
  3. H20Fidelity Contributor
    Long as it's not overly narrow like DX50, l don't know how others feel but DX50 stage width to my ears is very restricted, worse than a Sansa clip. From line out it is better.
  4. twister6 Contributor
    If you are comparing DX50 soundstage to being worse than Sansa Clip, then I think it's safely to say that X1 will beat that :wink:
  5. x RELIC x Contributor
    The interface for USB control on your Toyota's stereo head unit is built for iDevices and will not give you the same amount of control with the FiiO devices. The only thing the USB will do for you is charge the FiiO device. You need to use the 3.5mm auxiliary jack in your car and you must control the music from the FiiO device.
  6. bassboysam
    that's what I assumed, but I wanted to make sure.  thanks!
  7. nappiguan
    Has anyone compared the sound signature to the x3 and x5?
  8. mdh994
    Has anyone tried connecting te fiio x1 into a home theartre av reciever usb port, does it act like a usb and plays the music or is it like android and comes up with different options when plugged into usb?
  9. batteraziiz
    Checking at least twice a day for a North American preorder link 56Iey5P.gif
  10. newskin
    I've been able to test one of the samples sent by Fiio to the distributors and the only thing I'm missing is the support to use it as a DAC with the computer, is there any chance to include this feature in next firmware's? In every other way I see this as a very good product.
  11. clee290
    Some things have to be left out so they can sell this at a fraction of the cost of other DAPs.
  12. Saoshyant
    For $100, expecting DAC feature might be a little much
  13. newskin
    I know, but I was expecting that they could bring it on with some firmware update, if the limitation is on the hardware it still is a stellar product, I've been testing it for a week and I'm quite pleased.
  14. TripBitShooter
    what is the DAC used? I remember it being one that could take 32/384 decoding.
  15. CH23
    FiiO has a few DAC devices, the X3, X5, E07k, E17, E18...
    To have this functionality build in into the X1, would make it more expensive, and would undermine the reason for the X3 to exist (partly)
    Saoshyant likes this.
