The FiiO X1 Discussion and Help and Support Thread |192K/24B|100mW | LO | inline remote
Discussion in 'Portable Source Gear' started by jamesfiio, Nov 20, 2013.
122 123 124 125 126 127 128 129 130 131
133 134 135 136 137 138 139 140 141 142
  1. BeBop Lives
    I would like to know the release date in the US for the X1 please.  Thank you very much.
  2. mangel312
    and some stores stocking it on release....
  3. twister6 Contributor
    The car mount should be universal with 17mm ball joint socket
    So you can attach either a suction cup base or air-vent mount or whatever other mount you would like to use (or to re-use), similar to smartphone car mounts.  As a matter of fact, would be good to slide out the socket plate from the back of the X1 holder to attach to armband holder, make it totally modular, something similar to Seidio Quest mounting system :wink: http://www.seidioonline.com/Articles.asp?ID=293
  4. x RELIC x Contributor
    ^^ This ^^
  5. CH23
    Why not something that fits the cupholder? (I do not own a car, btw.)
  6. mpawluk91
    it looks OK but I don't like how the cable is on top of the player, it looks like it will get in the way
    Maybe if the stand itself plugged into the Jack on top, and you plug your own aux cable into the stand
    I think that would be very cool
  7. caudex
    Anybody tried the X1 and IHIFI770? Any comparisions as to which one is better in terms of SQ?
    They are both priced at around the same price.
  8. VXAce
    As an idea for a case for the X1 (or really any DAP), what about a case that goes on the belt? One where you still have control of all the buttons, but still secure (kinda like a holster for a handgun).
    No I didn't think this one all the way through yet, but it seems like a decent idea. I do some biking, and having my iPod in my pocket can be annoying, but on the belt it might be more comfortable? I bike in normal pants, not a bunny suit.
  9. caudex
    Either that or have support for iPhone/Android 3 button remotes. Up and Down can have track forward and track back, then if you press the middle call button, it switches the up and down button to Volume Up and Down. Would be awesome feature!
  10. clee290
    Middle is usually play/pause. Double-click middle is next track and triple-click is previous track. At least that's how the Apple ones work.
  11. twister6 Contributor
    Wait for X7 to support this.
  12. thrones
    does it take a while to read the sdcard when new songs added?
    this is annoying in the sansa clip for instance.
  13. JamesFiiO Contributor
    not, you can play the music by folder play and it will not take time to do that. but if you want to play by artist, album, you may need to updated the music library first. but it is quite fast .
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  14. JamesFiiO Contributor
    we will make some Line out cable for X1 and the new DAP, DAC/AMP... which is use the micro USB so you have not problem to connect the X1 to your car audio from the bottom.
  15. doublea71
    No - it's very fast. On another note, this thing pairs surprisingly well with my UM Miracles - no joke!
