The discovery thread!
Feb 24, 2024 at 12:46 PM Post #95,701 of 111,773
I don't know what's a dumber dongle design, the Hidizs SD2 or the GameBoy-looking dongle with non-functioning A/B buttons.
Please: Just give me the smallest stick or rectangle possible with balanced and SE input and clean, ample power. That's all we f*cking need from a dongle! (Well, onboard parametric EQ like the Qudelix 5K is nice, too ... )
P.S.: Your alliterative linguistic test for the day is to say "dumber dongle design" 10 times fast. :)
Feb 24, 2024 at 12:47 PM Post #95,702 of 111,773
I'd like to mention sth special about Dunu s&s tips.
I honestly like them. However, they're kind of tips that won't suit many in your collection due their strange curve.
They're good with long nozzled IEMs that will enter with substantial portion to your ear canal. They don't like shallow insertion. They don't hold well.
But it creates a magic if you go all the way in. I also find it better if they're barely in front of nozzle giving that customized IEMs sensation. I was using them on my Land before I switch to Trn Wide Bore tips.
More Air and details because of the reduced mid bass you hear more spacial clues and stage
You're right. It usually occurs when there's no channel division. Bass dominates the other frequencies all from the beginning :)
Feb 24, 2024 at 12:53 PM Post #95,703 of 111,773
I wonder if you are getting version 2? Or if they still had some originals laying around
Good question, any way to know?
Feb 24, 2024 at 12:55 PM Post #95,704 of 111,773
I personally can't use Dongle DAC/AMPs much except a few models(which i specifically like for their sound, models such as AFUL SnowyNight, Questyle M15, L&P W4 are among them). But I love using my Questyle CMA18P. It is the most convenient piece of gear with ultimate sonic capabilities. I have sent it to my friend for trying and he is liking it too much that he is gonna keep it for another week haha. I liked this Quloos MUB1 as well(it came to me for review, shoot it done, I might post it in the next few days, not running very well health wise).
Feb 24, 2024 at 12:56 PM Post #95,705 of 111,773
Feb 24, 2024 at 2:04 PM Post #95,706 of 111,773
Unlike others, I can only write good things about Kiwi Ears Forteza. True, this is a set with pronounced highs, but it also has excellent bass and midbass, a classic V shape that works well with indie, alternative and hard rock. I equalized it a little with the Qudelix 5K and the result is really good... if you're in the mood and want to fill up with energy!
I hope I'm not the only one who appreciates it.
I didn't get the Melody, as I already have the P1 Max which, properly amplified with the DL200, can already give me great harmony and emotions, listening to great music for hours.
Feb 24, 2024 at 3:01 PM Post #95,707 of 111,773
Are those tips you get as stock with Dunu Falcon Ultra?
If they are, then I have them on Falcon Ultra, and they are a great fit.
The same tips I tried with the Final Audio B3, and the sound was horrible...terrifying :)
It seems that these are great tips as far as I am concerned, but they don't suit every IEM well.
Feb 24, 2024 at 3:02 PM Post #95,708 of 111,773
I am also working on MP145 right now. I love that IEM, only con for me maybe the size haha.
I like it also, find it better than the S12 Pro. And some other older planars I have used, of current new models it depends.
Negatives is mostly the size for most people and also the sharp edges for me, the angle is also quite aggressive on the nozzle. Tbh the size is not a big concern for my larger ears.
But the negatives here are very personal
Tuning is very good, MP145 is a musical and fun planar.
Feb 24, 2024 at 3:16 PM Post #95,709 of 111,773
Promised Hidizs to share what I think about the SD2 dongle, so here's a small post about it. Also thanks for sending me the dongle together with the MP145.
The ESS implementation has no sharp brightness to it, its actually quite warm and smooth sounding. Not at the level of Colorfly CDA M1P in warmth, but not that far off.
Most Cirrus Logic dongles like Truthear Shio or Simgot DEW4X is more resolving and dynamic sounding, and I much preffer those. Weak power output that's quite notable on harder to drive planar IEMs.
There is also the awkward design that to me dont look pleasing or premium at all, would almost believe this was a gamer dongle made by Asus.
The way its made also make it really easy to get strain on the phone port you use, the design having no cable do make it less bother some when in your pants and that's a positive. My problem is that the USB C is slightly small compared to most other dongles I have with USB C, so if your like me who have a phone with plug that's more loose it will loose connection way to easy.
Another thing its impossible to position the phone and the dongle in my work car phone holder, probably other phone holder that can work.
There is also the occasionally pop noise it picks up from both my work phone and private one, this is not here on dongles like CDA M1P or DEW4X. Doubt Hidizs will like this post, so ill end it now with a pro con list.
Pro
  • Price
  • Small size
  • Support Microphone cable
  • Warm smooth tonality
  • Led Light for sampling rate
  • Longer USB C part works with most phone cases
Con
  • Design
  • Not most resolving dongle
  • Awkward build
  • No balanced
  • Easy to get usb strain due to fixed design
  • No volume buttons
  • Not very powerful as a dongle
Then the next thing I will write about is their planar MP145, not that negative there. But also got something to complain about :beerchug:
lol what on earth is this dongle
I guess I need to get pumping on that MP145 review…
Feb 24, 2024 at 3:18 PM Post #95,710 of 111,773
Negatives is mostly size for most people and also the sharp edges for me, the angle is also quite aggressive on the nozzle. Tbh the size is not a big concern for my larger ears.
Exactly man!! I am using one today to play some Banishers: Ghosts of New Eden on my ROG Ally :p
Feb 24, 2024 at 5:03 PM Post #95,713 of 111,773
The 2024 coming AirPods will revolutionize the industry.
“There is a need for a headphone case device that can control operations that are traditionally associated with headphones (e.g., playback controls, changing audio sources, changing audio output modes, etc.). There is a further need for a headphone case that can also convey information to a user, through haptics and/or display devices. Such methods and interfaces optionally complement conventional methods for controlling wireless headphones. Such methods and interfaces reduce the number, extent, and/or nature of the inputs from a user and produce a more efficient human-machine interface.”
Feb 24, 2024 at 5:14 PM Post #95,714 of 111,773
I was reading another article about this yesterday. I like the idea. They have to do something since there are now many TWS sets that rival the AirPods Pro 2 in terms of noise cancellation and transparency functions. Additionally, Apple’s drivers sound marginal at best. They mitigate it some in software but if Apple was smart they’d put a far better driver in them and reduce the computational meddling. But yeah. A functional case is a great idea.
Feb 24, 2024 at 5:34 PM Post #95,715 of 111,773
Just reading that gave me the tingles LOL
