The Deals DISCUSSION Thread (READ THE FIRST POST!!!)
  1. Poki
  2. PlantsmanTX
  3. kenchar
    Thanks for this!
    Got the Plenue 2....great DAP for the price.
    Ken.
    gemNeye likes this.
  4. LCMusicLover
    This!
    Seriously, at that price I considered purchasing a second one, just 'cuz.
    Kinda painful when I recall that I paid more than twice that not so long ago. Lucky I'm getting forgetful as I get older :)
    gemNeye likes this.
  5. groucho69
    gemNeye and Slater like this.
  6. OldDude04
    I got my HE-560 headband in earlier today (thanks again @PlantsmanTX), and I've already done some bending and it's attached to my modded M1060's. I had a LCD-2 leather headband and yoke assembly on them before, and I had to drill out a bit of wood to use the Audeze yoke screws. That worked in my favor because with the HiFiMan headband, I am still using those screws. I just had to bend the ends of the yokes to set more flush to the M1060 and boom, new headset. Now, I'll probably have to paint the section of the 2 orange bands and the black in-between them to remove the HFM logos and text. Anyway, here are a few pics:
    Ggroch, barondla, Mad Max and 9 others like this.
  7. Slater
    You don’t even want to know what I paid for my 2x256GB Samsung micro SDs when they 1st came out.
  8. Kundi
    I do
    Mad Max likes this.
  9. Cruelhand Luke
    Noooo, it will just blow your mind you fool!
    Mad Max likes this.
  10. PlantsmanTX
    You're very welcome...looking good!
    OldDude04 likes this.
  11. Th3Drizzl3
    looks great like that minus the logo. i got mine also yesterday. i have 4 backups now lol. appreciate the link!
  12. Ggroch
    Does anyone know a source for the screw sets....or perhaps an idea on other screw combos that will work. I have an original 560 with the plastic yokes...so no screws. My original band has been fine so far, but I would hate to have it break when I try to remove it and then not have the hardware to put on the replacement.
  13. OldDude04
    It's been a while since I owned my gen 1 560's so I don't know if it would work for you, but I used THIS kit to mod my M1060 to accept the Audeze yokes. I'm still using the pieces in the pic below with the new headband, minus the Audeze yoke rods. I drilled a hole for the pieces on the left to be pressed into the headphones. (Drilled the hole very slightly smaller than the cylinder size so it stayed in place when pressed in). It was a pretty simple process.
    Ggroch likes this.
  14. Th3Drizzl3
    our lowes has some pretty tiny allen head screws. not sure if they have ones that will fit but worth a shot. might just have to be shortened a bit
    Ggroch likes this.
  15. gemNeye
    trellus and phthora like this.
