n00b2
- May 14, 2013
Good feedback @andrenb. What exactly are you looking for in the newer models you are trying since you seem to be pretty happy with the Zik apart from battery life?
I'm looking for mainly two things, one is better battery life as you mentioned and the other better sound quality when used in passive mode with the cable. The battery usually won't last for my commute + workday as the battery usually dies after approximately 6 hours so I have to charge it in the middle of the day if I want to avoid using it in passive mode on the way home. The other thing is that I find it barely tolerable when listening in passive mode, of course it's better with a little bit of sound when the battery dies than no sound at all, but I really can't enjoy it in that mode.
The Sennheiser Momentum Wireless AE would be my absolute favorite if it wasn't for the bluetooth trouble and problematic microphone quality on calls. Excellent battery life and good sound quality even in passive mode, and good enough ANC in my opinion. Another favorite is the B&W P5 Wireless with it's great size, sound quality in both active and passive mode and good battery life. But it lacks ANC which I just can't live without.
Fair enough. There's not a lot left to check out really. The Denon is a decent option that seems to be hard to find. So is the Definitive Technology Symphony 1 though that is a bit large and just as hard to find (unless you are into importing from Amazon US).
There is also the Momentum Wireless on ear and Sennheiser Urbanite Wireless which don't seem to have the same bluetooth complaints as the Momentum Wireless over ear. Probably not as good sound quality but could be worth a look.
