AlterSack
- Sep 28, 2013
Is it the same MacBook that You have used before?
Are You sure You have downloaded the correct file? Maybe try again from a different Server?
You could use
http://astellnkern.de/
The german Server is quite reliable.
Does anyone know if it's possible to move music out of a folder into another folder using the Android File Transfer app? I have successfully used this app to move music (.aiff, .flac) onto the device, but it doesn't seem capable of moving the music once it's in a folder.
