The AKG K712 Pro Support and Impressions Thread
Nov 29, 2014 at 8:05 AM Post #3,557 of 6,171
BillsonChang007
Johor, Malaysia
Technically speaking, the AKG K7[whatever] series can be driven right off an iPhone if you wish to but the result wouldn't be at it's best performance.
Having tried E07K, E09K, iFi Micro iDSD, and Garage1217 PS3, the AKG K7something is best paired with something that offers good dynamic range, warm, and powerful.
Billson :)
Nov 29, 2014 at 1:19 PM Post #3,559 of 6,171
Boelie
I just bought a K712 and I am now in the market for a good portable dac/amp.
I know that there is a lot of talk in this forum about what is the best amp in combination with the K712.
But somehow I couldn't find a good advice. I am looking in the price range $ 150 - $ 250.
Any suggestions?
Nov 29, 2014 at 6:15 PM Post #3,560 of 6,171
BillsonChang007
Johor, Malaysia
Any suggestions?
FiiO E07K + Garage1217 Project Sunrise III with 6AU7 tube. :)
Nov 30, 2014 at 10:35 PM Post #3,561 of 6,171
DivergeUnify
Im now considering getting these over the HE500s. Are the K712s fatiguing at all? People seem to describe them as darker, but not sure if thats relative to the previous 7 series offerings. Also how do these fair with metal? They need to be an all arounder for me, which would consist of rock, metal, electronic, and jazz.
The fact that theyre significantly lighter and more comfortable than the he500 really sells me. If i get them, i plan on using the O2/ODAC. I saw a lot of comparison earlier in the thread, but wanted to see how thoughts have changed. Compared to the he500s, how does the bass/mids/treble compare (stronger/weaker per range) to the 500.
Theyre nearly $100 cheaper which makes them seem really competitive
Dec 1, 2014 at 1:00 PM Post #3,563 of 6,171
HaVoC-28
  The K712 are less darker than the bright original K701/2 but definitely not dark like HD600/HD650 for instance :)
Depending on the recording my gone K702 65th annie could be a bit darker overall than my HD600 (direct comparison) ...
Dec 1, 2014 at 7:02 PM Post #3,565 of 6,171
BillsonChang007
Johor, Malaysia
You mean  more dark than the K701/2s .....I hope...but yes less dark than the HD600/650s.
yes. Typo. Thanks guys for the correction!
Let me rephrase it myself:
The K712 / K702/65 is darker than the original K701/2 that is pretty bright. However, the K712 / K702/65 is less dark than the HD600/HD650.
Dec 1, 2014 at 9:05 PM Post #3,566 of 6,171
kman1211
Edmond, OK
Basically, and the K702 Annies are a little darker than the K712. The Q701 is also darker than the K701/2 but not Annie/K712 dark. The HD 600/650 are definitely darker than the K712/Annies, almost too much so at times.
Dec 2, 2014 at 1:53 AM Post #3,567 of 6,171
gabrielnorena
I find the K712 pro a little bit darker than the K702/65th, but both are still very natural-balanced sounding... Anyway, I agree, the HD600 were too dark for my taste.
Dec 2, 2014 at 9:41 AM Post #3,568 of 6,171
kman1211
Edmond, OK
I thinks its the K712's brighter upper treble that makes it come across as a little brighter than the Annies to me. Putting on my HD 600 for the first time took me aback at it's darkness as I didn't remember the HD 600 being so dark when I first heard the HD 600 and the fact everyone says it's so neutral.
Dec 2, 2014 at 9:54 AM Post #3,569 of 6,171
gabrielnorena
Ok, I really don't know if older Annies are darker, mine are late production unit and have the same pads that the K712, so maybe that makes them a little less dark... Maybe the new K7XX will be as dark as the older Annies as they are rumored to have older Annie pads... I'm really happy with my K702/65th the way they are.
Dec 2, 2014 at 10:04 AM Post #3,570 of 6,171
kman1211
Edmond, OK
So basically the K712s and Annies drivers are tuned differently? What would you say are the differences between the two? I've heard the old Annies personally.
