- Oct 14, 2013
I didn't try the 4 cut out on the exact holes, because the pads are easily rolled around, and hence it could be out of places. I did the circumferences cut
Leakages is due to the thicker or thinner leather on the base of the pads, and nothing to do with the plastic holes. I couldn't confirm before, but with the Brainwavz pads, I could observe it as they have thicker base leather, they isolate better.
The stock pads has a nice solid leather glues underneath which is very strong and durable. If you trim it just enough, there would still be enough glue to hold them together tight and sweet.
Now, if you cut the Brainwavz pad, they do not have those glues (only a bit), so it would be better to be more careful.
