KeithEmo
Member of the Trade: Emotiva
- Aug 13, 2014
That's an interesting question..... and it would apply specifically to a single impulse.
If you watch the kick drum, you'll see the drumhead move a clearly visible fraction of an inch in the forward direction when the beater hits it.
If you equate that to a 24" subwoofer moving a half inch it's clearly a significant amount of energy in one pulse.
And, considering that the drumhead and the beater are both pretty heavy, and moving relatively slowly, I would assume a significant portion of it is at a very low frequency.
Descriptions of the frequency spectrum of bass drums vary widely - and many state "as low as 20 Hz" - while many also seem to consider 30 Hz as the lowest common fundamental.
However, nobody seems to rate the energy in terms of what's present in the single starting impulse rather that what's present in the oscillation that follows it.
If we include things like those enormous Japanese Taiko drums, then I would assume that at least some go far lower.
At least some few pipe organs include one or more 16 Hz pipes.
Considering how much trouble most older speakers, and vinyl cutting lathes, have with such low frequencies, I suspect they are often deliberately filtered out.
I would note that most digital recording equipment has no trouble whatsoever with even extremely low frequencies.
However, vinyl records, and record equipment, have a lot of trouble with very low frequencies.
(Low frequencies take up a lot of track space, risk exciting mechanical resonances in the turntable and tonearm, and a lot of vinyl equipment has a deliberate low-frequency roll off to reduce rumble and record warp.)
Many speakers, especially before subwoofers became common, also had trouble with very low frequencies (excessive cone movement and very little output).
I believe many tape decks also have trouble with very low frequencies (because tape heads are inductors) - but I could be wrong there.
This suggests several reasons why many recordings, and especially older ones, probably limit their very low frequency response.)
I can see that being true of a great big tympani drum, but would the standard kick drum in a rock group put out significant levels down at 15Hz too?
I'm not looking at the theory here. I'm looking at typical music. What kind of music would have a lot of sub 20Hz content? I've played a lot with my equalizers and to me, it seems like most recorded music doesn't have a lot below 40Hz, much less as low as 15Hz. Most bass I find is between around 50Hz and 200Hz. I've found that it's rare to find anything in recorded music that goes down much lower than 40Hz. I imagine it's there in theory, but it isn't at an audible volume over the rest of the drum hit.
I realize I'm generalizing here. I'm just trying to understand where this all fits in the real world. Maybe there's a kind of music where sub bass is important and I'm just not aware of it.
