Technical question about output power of an amp
post-10657716
Thread Starter
Post #1 of 4
Sam21
If an amp's spec says it has a maximum of 5W power at 32 Ohms , how can we figure out the maximum output power at a different impedance  say, at 600 ohm ?
I am guessing it cannot be determined ?
post-10657734
Post #2 of 4
Sam21
do I have to look at the amp's maximum voltage output ?
Guess I figured it out.... I use the max output voltage then choose my impedance find I using the Ohm's law then P=I*V
Am I correct ?
post-10659322
Post #4 of 4
cel4145
grand rapids, mi
grand rapids, mi
You can't do that reliably. Some amps are better at low impedance output. Some at higher impedance.
