- Oct 6, 2013
Alex are you using the stock cable or then Linum Bax with them? I havent tried them with the Bax yet.
BaX only!!! Once you switch to it, you will not go back Btw, from what I understand, Ei.xx Drop will offer an option to buy Linum Music and BaX at a special price. I would HIGHLY recommend BaX, it has a great synergy with Ei.xx to refine the sound. The only drawback, with stock or any other cable that has memory wire it makes it easier to remove CIEMs when holding on to memory wire portion. BaX is super thin without a need for memory wire, so I'm trying to grab a connector when I remove Ei.xx.
