how is it defensive when u didn't even provide a simple alternatives.
My post was not about providing alternatives. It was about Oxygen pricing regarding its "faults" - need for "upgrade" cable (#1 product package value issue) and short nozzle (#2 design issue).
#1 - for price near 300$ customer wouldn`t want to spend any additional cost for another basic part of quality IEM package. 60$ extra isn`t cheap for something that should be already in the bundle to get the best out of product it is able to provide.
I mean, for example, iBasso can provide cable with high value (material quality and low impedance) with 100$ package and 60$ can almost get You Tin T3 with also high quality cable included in package.
Market is very competitive and this is not the place where product should "require" You spend more. Get my point?
#2 - if You look at popular IEM designs which are good "average" for everybody (always exceptions though), most of them have "average" length and angle nozzles - Oxygen is not one from those.
I have nothing against tip-rolling (I love tip-rolling as it brings more "options") but when nozzle is short, that tip-rolling gets very limited and thus "sound & fit tuning" also limited. I have extensive collection of different tips for my ear size (S) but for Oxygen there will be only few options with longer tip stem/barrel. I have had similar shape and nozzle length IEMs before and know that would be issue for me. That is one of reasons I went with KPE (which nozzle looks long on pics but actually is same as ZSN or IT01 for example, which have quite "average" nozzle length/angle design).
You and some others were ones who went straight away into defending position and started to compare Oxygen to KPE (guess my avatar and it being current favourite atm affected this).
Really, Oxygen WAS on my choice table... BUT (since You started this comparison Yourself):
1) KPE vs. Oxygen reviews left me with overall impression that they both sound very similar and choice is depending on personal sound signature preferences, gear matchup and money. I`m still thinking same despite many reviews saying Oxygen is better.
It is all about HOW much better? Are You saying that Oxygen is @ another level up? You know there are ppl preferring KPE out there? You know there are reviewers saying that if You already have one then the other is not worth to get regarding price?
Since I got a glimpse chance to get KPE for only 126€ (I would pay full price for them anyway as they are more than worth it) and Oxygen had(has) previouskly mentioned issues, plus my personal preferences were also rather KPE-sided, I went with KPE.
2) They both measure very similarly.
3) KPE has already good quality cable in package (Btw, MD updated their cable to provide better value and quality leaving price same and Lyre Acoustics cables are known to be good).
4) KPE has it`s own issues like heavy weight and finishing which both are no issue to me as I live in relatively cool/dry climate and wear IEMs over-ear with deep fit.
5) KPE also has issue with tips sliding down nozzle and thus changing SQ/fit experience but I rather have this problem (which is easily solved by simple "slip-stop" rings) than short nozzle issue.
is it defensive to say its a logical decision to buy the best iem you can get with a certain budget u set.
I was talking about price vs. value not about certain budget!
If I had 330$ in my pocket for IEM atm - I would probably save up little more and get something else. If it would be max budget regardless what, I would still choose something else because of those mentioned subjective issues.
i really don't get it, u want an objective discussion then atleast provide some onjective argument instead of relying with the subjective "worth value"
I was trying to "slow down" this "upgrade cable definitely needed" train and bring attention to price vs. value.
I had long though before posting this as it may cause flaming and arguing within thread. I decided to explain my views and I hope they are understood now.
I will not post here anymore as I`m not planning to get Oxygen as I already have KPE and was just viewing previously subscribed thread because of purchase interest.
Unsubscribed.
Bye.
