Ordered from the Takstar store, they adjusted my order and I had a coupon applied, Aliexpress said coupon was in violation or something and automatically canceled my order despite charging my card... now I'm waiting for a refund lol. With regards to that, even if they sound good I really dislike the design of the headphones so I will not be reordering sadly.
Takstar Pro 82/GM200 Review, impressions and discussion thread
- Thread starter BenF
BenF
- Jan 22, 2013
So the reason for cancellation by Aliexpress was an "incorrectly" applied Aliexpress coupon - why do they allow applying it then?Ordered from the Takstar store, they adjusted my order and I had a coupon applied, Aliexpress said coupon was in violation or something and automatically canceled my order despite charging my card... now I'm waiting for a refund lol. With regards to that, even if they sound good I really dislike the design of the headphones so I will not be reordering sadly.
They sure still have some work to do on providing smoother buying experience.
daid1
- Jul 15, 2013
daid1
- Jul 15, 2013
I know nothing about cable, but only out of curiosity, I did sme research on aliexpress looking cables with 3.5 and 2.5mm terminations, is there anything which seems good and worth buying?
is the pdf visible?
bunkbail
Nope, the notification said you attached something but nothing's attached there.is the pdf visible?
daid1
- Jul 15, 2013
how can I do, the file is attached but not visible
bunkbail
What are you trying to attach? Perhaps you should host it to somewhere else and link it here? That's what I always do on forums anyways.
daid1
- Jul 15, 2013
it is a pdf
I did what you said here the link https://www.dropbox.com/s/ef2cx37imb7v5ca/cablesss.pdf?dl=0
BenF
- Jan 22, 2013
Some of these cables may have too fat housing of the 2.5mm plug to fit into Pro 82.it is a pdf
This cable works for sure, has a mic and Android/iOS controls:
https://www.aliexpress.com/item/Upg...ack-Cable-Mic-For-Bose-Quiet/32810246600.html
P.S. When posting Aliexpress links, please replace "it" with "www" - most people here don't speak Italian
daid1
- Jul 15, 2013
corrected
I thought that some cable are not suitable for the pro 82, but I ask you if there is something which seems worth buying it, to have some more options
BenF
- Jan 22, 2013
Depends what you mean by "worth buying it". If you want to improve the SQ, the provided cable is great and you will have a hard time trying to find something better.corrected
If you just want a prettier cable - you can take a chance with some of the cables you listed - maybe they'll fit, maybe they won't.
daid1
- Jul 15, 2013
to improve the SQ, yes, if it is possible, and to have a shorter cable than the provided one
I don't have the headphone, for now, so I asked here to anyone that already have one and have a knowledge in cables (because there are so many different type and I am not able to recognize if it is a good cable or not) if there is something noteworthy in that list and which can fit on the takstar
Supa Boy
Guys, can you help or guide me? The famous and super-sold gamer headset Hyperx Cloud Core is based on the Takstar Pro 80 headphone, my question is: is the Takstar Pro 82 even better for gaming? Compared to the Takstar Pro 80 or Hyperx Cloud Core, is imaging any better? Is the sound stage bigger?
BenF
- Jan 22, 2013
Takstar Pro 82 has better imaging and larger soundstage then Pro 80 in music, should be applicable to games too.Guys, can you help or guide me? The famous and super-sold gamer headset Hyperx Cloud Core is based on the Takstar Pro 80 headphone, my question is: is the Takstar Pro 82 even better for gaming? Compared to the Takstar Pro 80 or Hyperx Cloud Core, is imaging any better? Is the sound stage bigger?
But it doesn't have a mic - better use a USB mic with it for games.
Oh, wow, thanks a ton!
Just updated the review for TH-X00 Purpleheart
https://ihearwhatihear.com/2017/12/30/takstar-pro-82-an-underdog-champs/
https://www.head-fi.org/showcase/takstar-pro-82.22388/reviews#review-19643
Total: 10 (members: 0, guests: 10)
