Let's talk about Reloop SHP-8.
Here are the measurements (smoothed 1/12th):
Looks pretty standard, but the bottom around 4Khz is deeper than expected.
Let's take a look at the non-smoothed one:
Left goes down to 33dB (51dB lower than 1Khz), and right goes down to 54dB (30 dB lower than 1kHz).
For comparison, I've added a non-smoothed re-measured Pro 82 v1:
Both channels go down only to 62dB on non-smoothed graph, 65dB on a 1/12th smoothed one.
Other than that 4kHz bottomless pit, SHP8's FR looks exactly like v1.
Since both SHP8 drivers exhibit the same issue, this is not a result of a random QC failure.
Either Reloop bought some cheaper drivers that weren't good enough to bear Takstar's name, or there is a change in dampening.
The good news are, this drop is narrow enough for most people not to hear it - I certainly didn't.
SHP8 sounds as good as Pro 82 v1, no audible issues.
Should you buy it?
Only if you really like the dark grey color and the large logo - it's much more expensive than Pro 82, and the only accessories are a 2.2m cable and a 3.5/6.5mm adapter.
Or maybe you want a headphone that was "designed in Germany"
Allthough I don't share @BenF enthuasim for pro82 I must say I have much respect for the work he does. It is awesome that people get actual measurements. Good work benf!
