Takstar Pro 82/GM200 Review, impressions and discussion thread
Which headphones do you want Pro 82 to be compared with?
  • Total voters
    39
  • Poll closed .
Nov 8, 2020 at 1:44 PM Post #3,631 of 4,535
Hey, i didnt have time to look at this. I am straight noob when it comes to this things, i have a friend who has some equipment and we are going to try some things to see if we can solve this. The noise only bothers me if im not listening to music. But so far im loving it. The major thing for me was the bass, without the combo it was not working for me, now its just purfect.
Exactly my impression! This synergy combo creates the tastiest, meatiest bass!
It doesn't boost the quantity of the bass, just changes the quality.
https://www.head-fi.org/threads/tak...scussion-thread.849965/page-141#post-14373423
When you have time later, please post detailed impression of Pro 82 on a previous dac/amp and this combo.
Nov 10, 2020 at 5:36 PM Post #3,632 of 4,535
Finally, a great Bluetooth companion for Pro 82 - FIIO BTR3K!
Left to right - Earstudio ES100, FIIO BTR3, FIIO BTR3K, FIIO BTR5, Qudelix 5K, xDuoo XQ-23, Shanling UP2, Shanling UP4.
Build/usability
Build quality is great, it doesn't get any better.
BTR3K comes with a removable plastic clip (like BTR5), unlike BTR3, which has a clip on its back permanently.
The "Volume up/down" button is much better than on BTR3, you can really feel it.
Volume resolution is 60 steps, so you can adjust it to your exact liking.
Using the FIIO Control app, you can use a 10-band equalizer (not over LDAC though), and choose different types of low-pass filters (mostly affects bass).
If you'll set BTR3K to "USB DAC first", BTR3K will still appear as the current audio deivce on your phone, but media playback on your phone will be muted.
However, if a call comes in - you will hear it through BTR3K.
I wish there was an option to turn off Bluetooth when using a wired connection, but there isn't one - so I have to disconnect BTR3K from the phone manually each time (to reduce noise interference in the wired mode).
BTR3K vs BTR3
Both have the same dimensions, but BTR3K is 2.5 grams lighter.
BTR3K looks very similar to BTR3, but it adds a balanced 2.5mm output at the bottom, and moves the USB port to the top.
BTR3K has slightly larger battery - 330mAh vs 300mAh, but both have the same battery life (up to 11 hours).
BTR3K is using Bluetooth 5.0 vs 4.2 in BTR3, but it is losing LHDC support because of this.
BTR3K is using a slightly more advanced DAC AK4377A vs AK4376A in BTR3, and has two of them.
Just like the much more expensive BTR5, BTR3K is using two independent crystal oscillators for 44.1kHz and 48kHz, reducing jitter.
Both drive 25mW into 32Ohm from the 3.5mm, but BTR3K can drive up to 78mW using the balanced 2.5mm output.
The only disadvantage in BTR3K is losing NFC, but I have never considered that feature important - you only use it once to connect to a transmitter (and not all of them support NFC anyway).
Sound impressions
BTR3K sounds exactly the same using Bluetooth (LDAC 660/990), as it does wired - so you will get consistent sound regardless of how you use it.
While BTR3K is limited to 16bit/44.1kHz and 16bit/48kHz in USB mode, I had no problem playing higher resolution files in Foobar2000, without any noticeable degradation in sound quality.
With Takstar Pro 82 v2, BTR3K was a revelation - I did not expect this level of performance from such a tiny and cheap device.
It's border-line synergy combo - but wrapped into a single device, which also provides Bluetooth!
Pro 82 v2 sounds very musical on BTR3K, regardless of connection type.
Throughout the entire frequency range, there is nothing to fault - even the bass is nearly perfect in both quantity and quality, only being very slightly improved by adding O2 amp.
BTR3K hits really hard with Pro 82 v2, and the bass has full body - really surprising for such a tiny device.
BTR3 sounded very transparent with Pro 82 v2, but the notes were too thin.
BTR5 had proper weight of the notes, but added a slight warm veil, losing the transparency.
BTR3K resolves both issues - the notes have the proper weight, while retaining perfect transparency, without even a hint of any veil.
BTR3K adds some very slight euphony to the sound, as if it has a hybrid tube pre-amp - I find this very pleasurable and accommodating in long listening sessions.
Thanks to this slightly euphonic sound, BTR3K is quite forgiving to badly recorded/mastered recordings, despite excellent detail retrieval.
Only comparing BTR3K directly vs SMSL Idea (Sabaj DA2) + O2 amp, I was able to rule it out as a synergy combo.
Standalone, it sounds better with Pro 82 v2 than any device in the picture above, except maybe Qudelix 5K - not because I think it sounds better, but only because I haven't tested it extensively yet.
Not only that, but BTR3K even sounds better standalone than SMSL Idea/Sabaj DA2, which sound a bit too dry without O2.
Unfortunately, BTR3K doesn't have the same synergy with O2 as Idea/DA2 - it sounds too perfect on its own to really benefit from an amp.
P.S. I do prefer ES100's sound for my IEMs, but I currently have 3rd one in 2 years dying on me - so can't really recommend it.
Microphone
The microphone is very good, I constantly use BTR3K for phone calls/Zoom/Teams.
Conclusion
BTR3K sounds much better than much more expensive Bluetooth receivers such as FIIO BTR5 or Shanling UP4, at a much lower price.
This is really a no-brainer, a universal device that provides great SQ over any type of connection.
If you are looking for a single device to use in any situation - BTR3K is the answer.
If you listen to music mostly at home/office, you still would be better off investing in a synergy combo for Pro 82 - Comparison of DACs/Amps
Where to get
You can get it here: https://www.aliexpress.com/item/4000849710696.html
Its normal price is 70$, but during the 11.11 sale (which is actually 2 days - November 11th and 12th), you can use Select Coupons to get 6$ off that, and then you can get "6$ off 50$" coupon playing Energy Lab in the Aliexpress app - bringing the total down to 58$!!!
Don't miss this opportunity!
Nov 12, 2020 at 1:31 PM Post #3,633 of 4,535
Here are some promo codes for Aliexpress on the 11.11 sale:
List was updated at 1PM Eastern Time, November 12th - they were still active at that time.
3$ off 20$ - AUTHEN1111
3$ off 30$ - LETYSHOP1120
4$ off 30$ - SINGLEDAY4
7$ off 50$ - EXPRESS1111
7.91$ off 55$ - PEPPERAE1111
10$ off 100$ - SINGLEDAY10
12$ off 110$ - SINGLEDAY12
12$ off 110$ - EPNSINGLE12
New coupon codes working at 10 PM Eastern time:
7$ off 50$ - 7ALIBUY1111
7$ off 50$ - ZUZUSINGLE7
10$ off 100$ - ZUZUSINGLE10
Codes are case-sensitive!
You can use these promo codes combined with Select Coupons and store coupons, but not with regular Aliexpress coupons.
Each code can be used only once per account, after that you will receive this error:
2762869
This doesn't mean that the promo code has expired - only that you can't use it again (unless you haven't used it yet - then it means that the code has expired).
Important - just like Aliexpress coupons, these codes can be used on combined order - you can order a 30$ item from one store, and 30$ item from another store - you will be able to use the 8$ off 60$ coupon.
You can also get the following coupons playing Energy Lab in the Aliexpress Lab (takes less than 15 minutes to get all three):
And you can get 2$ off 15$, 7$ off 50$ and 10$ off 100$ coupons in exchange for coins ( coupons are refreshed every hour):
You can purchase this Takstar Pro 82 "synergy" combo :
Little Bear P10 for 45.5$ ( after 6$ in Select coupons and "7$ off 50$" code/coupon) - https://www.aliexpress.com/item/32882901310.html
ELE EL-D01 for 13.29$ (13$ after your "2$ off 15$" code) - https://www.aliexpress.com/item/32846934366.html
Or you can buy Sabaj DA2 (exact replica of SMSL Idea) for 49$ ( after "7$ off 50$" code/coupon) - https://www.aliexpress.com/item/32825193760.html
My recent favorite FIIO BTR3K for 57$ (after 6$ Select Coupon and "7$ off 50$" code/coupon) - https://www.aliexpress.com/item/4000849710696.html
(see review here - https://www.head-fi.org/showcase/fi...bluetooth-amp.24317/reviews#item-review-24719 )
And of course:
Guaranteed Pro 82 v2 for 49.6$ (after the "7.91$ off 55$ " code) - https://www.aliexpress.com/item/32808454492.html
GM200 for 51.5$ (after the "7.91$ off 55$ "code) - https://www.aliexpress.com/item/33012705103.html
Some comparison of frequency response between Pro 82 v2, GM200 and the 1700$ Fostex TH900 MK2:
2762879
Nov 13, 2020 at 6:42 AM Post #3,635 of 4,535
My Beyerdynamic DT990 DT 990 250 Ohm just came in. I have to say they blew away the TAKSTAR HI2050 I had earlier. There is simply no comparison when it cames to the stage, the bass, treble, and everything. The music which I listen to now has a "soul", and I have to say after listing certain tracks, they are becoming emotional too. Not sure how they will compare to the TAKSTARs 82 pro v2, but I will still get them for phone/mp3 usage for external use (bus, trip, etc), as the 32 Ohm doesnt require an external source. They are totaly worth the 2.5x higher price when compared to the HI 2050's, and not to mention, if they last more than 5 years...
Nov 13, 2020 at 8:58 PM Post #3,636 of 4,535
Pro 82 will work fine from a smartphone/mp3, but don't expect to provide the TOTL sound quality described in this thread.
For that, you need a proper DAC/amp: https://www.head-fi.org/threads/tak...discussion-thread.849965/page-5#post-13501419
Nov 14, 2020 at 7:38 AM Post #3,638 of 4,535
Does the LKYYR3GWIAE2 code still work? It says code is invalid
The codes have expired, I have asked for new ones - hopefully we'll get them in a couple of days.
Is there basically any other store besides official one on Ali that doesn't sell fake one ?
Other than TakstarAudio and TakstarOfficial stores, I wouldn't risk it. Got two v0.9 myself shopping elsewhere...
Nov 14, 2020 at 1:27 PM Post #3,640 of 4,535
oh wow that TakstarAudio has free shipping as well
They work really hard on keeping that 99.5% store rating :jecklinsmile:
Not only do they guarantee the v2 version, but they do a great job at packing. No matter how negligent your local postal service is, the headphones will always come in perfect condition. Usually takes me 5-10 minutes to get through their packaging to the item :jecklinsmile:
Other stores aren't as diligent with packing:
Why do some people prefer to save a few dollars at expense of guaranteed quality and safe packaging?
Maybe they are not reading Head-Fi?
Nov 14, 2020 at 1:51 PM Post #3,641 of 4,535
Yeah it's weird - I mean they risk not only reputation but also potential refund or re-send . Don't understand logic in that.
I'm torn between PRO82's and CM clones MH751. Maybe I'll wait till black friday and 82's price will be just too good to pass :)
BTW you guys should look into CouponPals on Ali as you can easly get $8/32 or $9/50 coupon to get price lower
Nov 14, 2020 at 6:41 PM Post #3,643 of 4,535
Just picked these up in black from Walmart web site for 42 bucks...
Nov 14, 2020 at 8:51 PM Post #3,644 of 4,535
MH751 is nowhere as good sounding as Pro 82/GM200:
https://www.head-fi.org/threads/tak...scussion-thread.849965/page-164#post-14832495
https://www.head-fi.org/threads/tak...scussion-thread.849965/page-180#post-14985125
https://www.head-fi.org/threads/tak...scussion-thread.849965/page-179#post-14982030
https://www.head-fi.org/threads/tak...scussion-thread.849965/page-195#post-15136282
Nov 14, 2020 at 10:13 PM Post #3,645 of 4,535
I would like to know how the Takstar Pro 82 compare to the Sennheiser HD280 Pro (New Model)
I was considering buying the Sennheiser for the PS5.
Why not just use Pro 82 with PS5? It has superb imaging and transparent sound, you will hear your enemies coming from afar.
