A new hybrid amp has arrived -
Little Bear P10.
It's surely is a good looking one:
Does it sound as good as it looks? You bet!
Here are some combinations I tried:
Oppo HA-2 - The sound is somewhat "tube-y", but not a great fit for Pro 82 - transparency loss is significant, and bass is not authoritative at all - there isn't enough "meat".
SMSL Idea - Since Idea is not a pure DAC, the sound becomes a lot warmer and just plain veiled, but the bass quality improves greatly. Oppo HA-2's DAC is not known to have any bass issues, so what's causing this improvement?
Could it be that P10 needs 2Vrms input (HA-2 is 1Vrms) for the bass to sound as it should?
ELE EL-D01 - You wanted "meat"? Welcome to the butcher shop! This combo sounds exactly like EL-D01 with FIIO E6 - there is a definite synergy!!!
Everything sounds very lifelike, listening to the same tracks for the 3rd time, I felt total immersion for the first time!
This is a very cold DAC, which makes it a perfect match with warm amps, and it does output 2Vrms, so bass is fantastic!
Since E6 is no more available, you can definitely go for this combo instead, although it's not portable.
P10 sounds a lot cleaner than Nobsound NS-02E .
If you own Pro 82, and don't own a synergy combo yet - this is your chance to get one dirt cheap.
Doesn't matter which version of Pro 82 you have, v1 or v2, as long as it's not v0.9 (a.k.a. "Dumpster" version) which is sold at some Ali stores right now, you will see how musical Pro 82 can get.
The cheapest price right now is here:
https://www.aliexpress.com/item/201...lifier-Stereo-Pre-Amp-Little/32882901310.html
The whole combo with EL-D01 will cost you ~75$!
At this price, you owe it to yourself to own one.
