system to experiment with 3D audio
Sep 23, 2016 at 12:07 PM Thread Starter Post #1 of 1
saltp8
Hello. I don't know why in the "cable, power, tweaks....." forum i don't have the "create a thread" button. This post would put there. So, maybe anyone could move it.
Anyway, I'm not an expert. So, if I'm asking for something meaningless, please do not get angry. I go straight to the point. I need a system to experiment with 3d audio with the following characteristics:
1) number of speakers: at least 10
2) each speaker is easily movable, transportable; possibly rests on the ground like a mic with a stand as a base (no screw, drills, attaching to the wall, etc);
3) fully programmable configurative system: to each speaker you can also be assigned only one channel, so as to more speakers can be assigned the same channel;
4) the software to manage it must be somehow integrable to Max MSP (or similar programs, no daw)
5) each speaker must have a bar so as to be able to be adjusted in elevation
6) rotating head for each speaker
what i'm asking is:
1) Is there a commercially available system that does this?
If yes:
1.1) Which is the cheapest?
If no:
1.2) Can i do this system with speakers that are not part of a system, ie separated?
Thanks so much,
Leonardo.
