System maintenance for Mac OSX?
Nov 27, 2006 at 9:22 PM Thread Starter Post #1 of 14
viator122
I've had my iBook G4 for about a year and a half now, and it is running much slower than when I got it. I have reinstalled the operating system twice now, but neither reinstall has been "from scratch" - each time I reinstalled in such a way as to keep my programs and settings.
Can anyone recommend utilities to improve my computer's performance?
Nov 27, 2006 at 10:14 PM Post #2 of 14
You can start by repairing the permissions using the disk utility, then try running the maintenance scripts manually, open a terminal window and type:
sudo periodic daily weekly monthly
Once the cursor returns the tasks are complete.
Or, download and install Onyx, and it'll do all the work for you.
http://www.macupdate.com/info.php/id/11582
Nov 27, 2006 at 10:50 PM Post #3 of 14
Thank you very much for posting that.
I just got a new MacBook and was very curious if there was a kind of disk utility for the OSX
Nov 28, 2006 at 4:26 AM Post #5 of 14
The best way to keep your computer snappy is to make sure it's got enough RAM (512 MB is the bare minimum you should have if you're running Tiger) and free hard drive space (more than "a couple" gigabytes).
In my experience, system reinstalls are rarely worth the trouble.
However, one good way to save space is to do an archive and install, but customize the install to not include the extra language packages.
Nov 28, 2006 at 11:35 PM Post #6 of 14
I ran Onyx last night and the Disk Utility. I am very happy with the results, thank you, AuroraProject. I have 512MB of RAM and about 27GB of free disk space, so that's not an issue. It's as though over the last 1.5 years the computer had become progressively slower, but those two procedures really brought it back to like-new condition. Thanks again.
Nov 29, 2006 at 6:46 PM Post #8 of 14
the ibook runs faster with more ram...i consider 512 a bare minimum. you'll notice a speed increase by increasing the ram.
also, if you download a ton of stuff (like i do) things will start accumulating all over the place on your mac...these can slow things down a little, like favicon image collections slowing safari. i try to trash anything i don't need...AppZapper is a good app that finds all the preference files associated with an app you want to get rid of and gets rid of that, too...
Nov 30, 2006 at 5:16 AM Post #10 of 14
Cocktail and Onyx are good choices, though Cocktail does number of things with your permissions.
Nov 30, 2006 at 6:09 AM Post #11 of 14
Just ran Onyx again, and it amazes me how much faster the MBP speeds up. I need more RAM though, 1GB is not cutting it.
Nov 30, 2006 at 7:09 AM Post #12 of 14
With minimal maintenance, OS X actually is faster with each successive OS upgrade (which in the computer world is quite something)
I think they say you should keep about 10% of your HD free...also, repair permissions before and after every OS/security update. These types of installs usually redo the prebindings (while it says it's optimizing system performance) so you don't have to worry about doing that. Then, if you want to run cron scripts, that's good, and I like to dump system cache and so forth monthly.
Nov 30, 2006 at 7:20 AM Post #13 of 14
yeah, it's amazing how apple does that...i was running panther on my original bondi blue imac with few hiccups. the only thing impeding the speed increase is the graphics card...they seem to get outdated much quicker than anything else.
good tip on the keeping about 10% of your HD free...i have a hard time doing this but when i do, it does feel snappier.
Nov 30, 2006 at 7:29 AM Post #14 of 14
