tme110
- Jan 21, 2011
It looks like the gymbals have changed again.
So how much are v4 drivers?
My Magnums arrived! I haven't listened to them yet, as I am planning to let them burn in for a while. I also uploaded an unboxing video CHECK IT OUT!
Excuse me, but what plastic ring are you guys referring to?
It's the beyerdynamic dt770 headband. The level of comfort is really good, in fact the only reason I can't listen to them longer than 3 hrs is because of the L-cush pads since they are relatively new. In terms of looks the headband is ok, I've been thinking about getting jmoney headband just for the better look, but their website is not working. So, in level of comfort I would recommend it and it's also relatively cheap.
You might want to take a look at the Manta leather headbands here: http://headphonelounge.com/products/grado-headbands/
Just got my black ones in today and they make a huuuuge difference in comfort level. The top of my skull used to start hurting after half an hour with my Magnumized MS2i with the old headband but no more. Also received them pretty quickly considering they came all the way from Malaysia.
Although what happened to Jmoney anyway? Is he still around? The website's been down for awhile now...
Interesting...wouldn't the s-cush/comfies be pretty much the same as the senn 414 pads unmodded? unless they're made out of different material I guess...
