cheemo
- Feb 23, 2008
Thanks for the impressions baka1969, I will look forward to reading your update in the future.
Originally Posted by EddieE /img/forum/go_quote.gif One thing that crosses my mind given the "plastic revelation" regarding SR325/MS2 is whether HF-2 actually has sound hitting metal, or whether the wooden driver hosuing inserts into plastic too. Any HF-2 owners out there had a look inside yet? |
Originally Posted by tim3320070 /img/forum/go_quote.gif You are doing the stock cable with red = left and white = right (seems backwards but that is how Grado does it, I have confirmed this)? If wired backwards, would you still have the Ohms read correctly? I say solder them reversed and see how that sounds. |
Originally Posted by Rhydon /img/forum/go_quote.gif Shawn, those headphones were purchased from a previous owner so i cannot vouch for their integrity. The part in question can be returned to its normal resting position by gently flexing the plastic forks to detach to the ear cups followed by reattaching them in a similar manor. If assembled correctly both forks should have a textured finish facing away from the ear pads. |
