Superdac modding - caps in signal path
Jun 15, 2005 at 12:13 AM Thread Starter Post #1 of 6
1UP
I recently got an M-Audio Superdac, and wish to mod it, as per a couple of guides on the net.
There are several caps in the analogue signal path - and I've read many times this is a bad thing. I've also read that depending on their purpose, they can sometimes be removed.
Can anyone therefore help me decipher this schematic and explain which caps do what in the circuit, and what mods could be made.
Jun 15, 2005 at 1:06 PM Post #2 of 6
you can bridge C42 & C46.. balance output will have 2.5V DC offset, but the unbalanced will be just fine..
Jun 15, 2005 at 2:23 PM Post #4 of 6
I read the AK datasheet and think it answers my question - certainly they use the 10uf electrolytic and 0.1uf ceramics around the DAC to filter high frequency noise.
I thought ceramic was considered bad choice for this.
Jun 15, 2005 at 3:12 PM Post #5 of 6
no these are supply decoupling caps, on each opamp supply rail leg and near the DAC they are either supply decoupling and/or reference voltage filtering.. low pass filters use ceramics..
Jun 15, 2005 at 7:00 PM Post #6 of 6
I've modded out my superdac fairly extensively. I'm using blackgate NX-hiQ 47uF's in there (in case I want to use the balanced outs at some point).
You can reach about it here, if you're interested:
http://www.motherone.com/projects/superdac/
It's a pretty dang good DAC..
