sceavis
- Apr 14, 2011
Is there anyway to add a Mirage Omni S-8 sub woofer to a pair of M-audio bx5a's with out any extra equipment? I am coming straight out of the computer to the speakers.
[size=1.7em] [/size]
Yes the sub has it's own crossover & phase control. All you need is a simple signal splitter & a extra set of cables. I use the same setup with my M-Audio BX5's & Tannoy subwoofer
That's not a crossover, it's a low-pass filter. It's not the same thing. Phase control should be assumed, quite honestly.![]()
Without an actual crossover, one (or both) sides are seeing the FR, and "integration" is only the result of roll-off.
There are subwoofers that do include crossovers, M-Audio makes one as a companion device for the BX5, and they work swimmingly. Alternately, you need something up-stream to handle the "thinking" for proper integration. And since you're already spending on that, you might as well just get an LMS and provide EQ correction at the same time (REW is free too!) - go for broke:
http://www.behringer.com/EN/Products/DCX2496.aspx (and yes, DCX over DEQ).
Let's see M-Audio speakers already have a high pass filter built in
