frog_a_lot
- Jul 30, 2007
I have narrowed my choice down to pretty much SJ5's..
Now i like the SJ5's and they are a good rpice, my only problem is i dont like the 2 sided cable, like one on each ear, and they done come with a 1/4 plug, or whatever its called...
The different plug isnt that big a deal.
I was also looking at the PRO5MS (yeh cause they look cool in camo) they ar e alittle more expensive, but they do have a longer and single cord, and a plug adapter that comes with it, but i have heard they dont have the sound quality of the SJ5's..
I dont want grado's or anything as i want closed back cans, and i dont like the senns such as the 212 or 280's.
So should i just buy the SJ5's and deal with the double cord and get a connecter for use with bigger jack.. or is there any other nice quality cans around i could buy for same price as the SJ5s
