Chapter 2 Is There a Chance for UTWS5 to Support LDAC, LHDC and aptX Lossless?
Regarding what you care about:
At present, it can be said that the UTWS5 is the most powerful Bluetooth earhook model in the HiFi industry. Many users asked whether it would support hi-res codecs, such as LDAC/LHDC and aptX lossless.
To let our users understand our plan more clearly, we would like to make an explanation here. Since the UTWS5 uses Qualcomm's flagship QCC5141 chip, which is currently Qualcomm's flagship programmable Bluetooth chip, quad-core processor system including dual 120MHz audio DSP and dual-core programmable SoC, and supports the latest ADK, it has many chances to upgrade. The actual situation of the 3 hi-res Bluetooth codecs is as follows.
LHDC:
As you all know, LHDC has been successfully applied to TWS headphones. But since it is our first time using the QCC5141, we had to be serious during the R&D process with many tests. We have initially confirmed that LHDC can be applied to the UTWS5, but we still need to further optimize the software.
LDAC:
Since LDAC is still under debugging in Qualcomm's TWS solution, we have not involved it into the UTWS5. If we can make breakthroughs, we will upgrade the UTWS5 with LDAC support.
aptX Lossless:
The UTWS5 supports Qualcomm Snapdragon sound suite of technologies. It is quite excellent at present. Since the aptX Lossless has just been released, and has not yet been widely applied, there is no chip support it. So the UTWS5 does not support it temporarily. If Qualcomm can support aptX Lossless on the QCC5141 platform stably in the future, we will also consider following up.
