Stax SRM323s hum on right channel.
post-7744784
Post #16 of 23
wind016
If you disconnect both RCAs from your source and the volume control is all the way down, is the hum still there?
Again with the source disconnected and you turn up the volume knob, does the hum get louder?
If your AC plug has a ground and you use a cheater plug to not connect the ground pin, is the hum still there?
I've never used a cheater plug before, but I know my source doesn't have a hum. The hum is only there when I bring the volume up on the 323s amp pot whether or not the source is connected.
post-7744816
Post #17 of 23
wuwhere
So your amp is amplifying the hum. Now that means the problem is in your amp. And it could be a failed component. It won't be easy to troubleshoot by yourself.
Read this, a shotgun way to fix a hum.
http://music-electronics-forum.com/t7152/
post-7745156
Post #18 of 23
wind016
Actually, I discovered something today. I don't know why I didn't think of this before. There is no hum at all on the maximum volume so I can use my source to adjust the volume and it's perfectly fine this way. Why do you suppose there is no hum at maximum volume? Pot issue?
post-7745473
Post #19 of 23
wuwhere
It could be that the volume pot is bad.
post-7745553
Post #20 of 23
K3cT
Time to get a can of electrical contact cleaner and clean the potentiometer's shaft. There should be some tutorial videos in Youtube that you can use as a rough guideline.
post-7745606
Post #21 of 23
wuwhere
Use Deoxit. You can also use Radio Shack TV-Tuner/Control cleaner lubricant.
That's an Alps pot. Here's a link from AA on cleaning it.
http://www.audioasylum.com/cgi/vt.mpl?f=amp&m=167154
post-7745791
Post #22 of 23
wind016
Thanks guys! I'll try to get it cleaned and see if the hum gets fixed.
post-7746400
Post #23 of 23
tyre
From your photos, it looks an Alps RK27 pot. It could be some type of interaction between the metal pot shaft and the case (assuming the case is grounded). Connecting the pot to ground through one of the pot's back screws might help. Check out Step 8 on this page of Tangent's site:
http://tangentsoft.net/audio/ppa/amp/steps.html
