I realise that a lot of SRX related matters have been posted in the great Stax thread, but I feel this one needs a resurrection. I've had a pair for about six months, but only recently made it work properly.
Pads were worn, balance between channels a bit askew. I cleaned the headphones up, removed and reconnected the driver terminals, and changed pads.
As most of you know, original pads were made with that humid sensitive polyurethane material that destroyed all PMB pads and the master tapes to Pink Floyd's The Wall. Original pads are almost impossible to get at a decent price in my part of the world, so I looked for substitutes. Found two options: Audio-Technica ESW 9 replacements, and Audio-Technica SJ5 DJ. Both fakes from Hong Kong.
Dismantled the SRX:
Removed and put back the three connectors (careful, the membrane is delicate):
The worn original pads:
The Audio-Technica EWS9, looks fine but not quite as comfortable and good-sounding as the SJ5 DJ alternative (original ESW9 pads may be better if you cand find them):
Preparing to attach the Audio-Technica SJ5 DJ pads, with double sided tape:
SJ5 DJ Pads in place:
Opening hole is about the same as the original:
Listened to and enjoyed the SRX very much yesterday. I also cleaned the original SRX pads, might be usable in the future:
A nice pair of cans:
