jenkinsontherun
I have a physically large head (though it doesn't do much ). If worst comes to worst, I'll just cut the fabric band right down the middle, then use some elastics to re-bind it. That essentially creates a larger head band.i bought those adaptors with brainwavz pads and didnt enjoy them after a bit of testing, it sits wrong on my head , especially with the original headband and then the sound signature is kinda wrong , muffled , however again others like it.
The original sound signature is much better but my ears where touching the grill, heating and the pads where toooo thin and almost hurting me.
Hopefully after getting the Vesper pads 20mm (i put the full specs earlier) and the more expensive sr-l700 headband, i just found bliss end game headphones .
It's what I did with the AKG K500. It's surprisingly comfortable. Of course, the resale value goes down the drain. The white string is a surgical mask band, which has great elasticity properties for this kind of mod. Snip snip.
NiceSome equipment have multi voltage PSU. The Playstation since the 3 comes to mind.
Others have a voltage selector, one mode supports 100-130v, the other 220-240v. A lot of desktop PC PSUs are like that. Sometimes the selector is covered by a sticker so it's not bumped or moved by accident to the other voltage. If you are lucky, the PSU will short circuit before dealing any damage to the internal components. Happened to a friend, everything else functioned alright, but the PSU was toasted.
In my case, I really hope that the step down converted doesn't get "lost" or impounded at my country's customs.
It happened to me before when I purchased a Schiit Magni 2 Uber amp to complete my Uber Stack, I did it via a PC parts importer. They gave me a generic wall wart that didn't work with the amp. I had to use the Modi wall wart in the Magni, and the generic wall wart on the Modi. It actually worked alright, but wasn't ideal. I had to buy a Schiit wall wart via an audio equipment importer.
For audio equipment I only trust importers and dealers specialized on them.
