STAX OmegaII has arrived!! O2 users help!
post-1466928
Post #16 of 29
PATB
San Jose, CA
San Jose, CA
I am not 100%, but the always ON bias must be getting the 580V bias voltage from the same power supply. In that case, if you have transformer hum, you are going to need more mechanical damping or clean up the power to your amp.
Do you use an AC conditioner? Try plugging directly to the wall or another outlet in the house.
post-1466960
Post #17 of 29
barilie
How will I do that, I'm very new in this matters...
What is a AC conditioner? Do I need one? Now I plugged directly to the wall. If the power is not clean, how could the buzz be away for some time? In the meantime the hum is there whithout interruption. Nothing (pressure....) helps anymore. I tried different plug-connections, but no difference.
post-1467038
Post #18 of 29
PATB
San Jose, CA
San Jose, CA
If you need mechanical damping, you may need to send the amp to Justin.
Some power supplies make a noise when used with some conditioners. Since you don't have one, that gets rid of that probability. I don't think you need a power conditioner unless your power is very dirty. I just use a hospital grade power strip for my system.
Time to send an e-mail to Justin. He has great customer service.
post-1468036
Post #19 of 29
spritzer
Member of the Trade: Mjölnir Audio
It is probably hum from either the main transformer or the small transformer on the bias supply. The always-on bias supply is a completely seperate unit with its own transformer. It can be seen here in close up (rather large picture). My unit also hums a bit but it doesn't bother me and it does no harm.
post-1468299
Post #20 of 29
KenB
Have you ruled out internal grounding problems? I had that condition with my STAX SR-313 amp, initially, although the hum was only noticeable when the volume knob was turned up above 6 (or 1:00 O'Clock on the dial). I solved it temporarily by running a wire from the external ground connector (back panel) to a cabinet screw. Subsequently, I received instructions from the manufacturer to simply carefully unscrew and remove the cabinet top and then reattach. That action must have accomplished a regrounding of the chassis because the hum immediately disappeared and has not recurred.
KenB
post-1468414
Post #21 of 29
barilie
I expressed myself in a wrong way: I can hear a clear hum or buzz IN the headphone!! When I said "the buzz comes from the KGBH", I wanted to make a difference between amp and digital source.
This is a part from my email to Justin from Headamp:
First there was a little buzz with the amp off. I thought then: the always on bias supply is working!
By switching on the unit, the buzz even increase. When I reconnected the jack the buzz stops, then I thought I plugged the jack too deep in the socket but after a while it came back.
Then with a little pressure on the back of the unit it stops again. But
finally there was was no remedy anymore to stop the buzz.
post-1470167
Post #22 of 29
pspivak
I hate to sound stupid (stoopid?) but have you isolated your problem to the amp? Be sure to check your cables. Be sure you are not too close to hum generating things like light bulbs and refrigerators and air conditioners.
Enjoy the o-2's
post-1470648
Post #23 of 29
barilie
I will check!
I did try three different plug-connections (in the same room) and there was no difference. I'll try in friend's house. But after my holidays in Scotland!
post-1470758
Post #24 of 29
gajira
I'm using a DIY KGSS.(PCB is Headamp's)I heard a hum from my O2 and
SR-003 too.When I touched a GND of cable,the hum went away.
So I guessed that the cause of hum problem is unstable GND of KGSS.
I connected wall's GND with KGSS's GND.
As a result,the hum has disappeared.
post-1470920
Post #25 of 29
barilie
Originally Posted by gajira
I'm using a DIY KGSS.(PCB is Headamp's)When I touched a GND of cable,the hum went away.
Sorry, but I don't know what "DIY", "PCB" and "GND" means.
post-1470936
Post #26 of 29
KenB
As I wrote to you earlier, it now sounds more and more like an internal chassis grounding problem which I experienced on my brand new STAX SR-313. The fact that the hum stopped when you pressed on the unit suggests that possibility. Something may have come a bit loose in the way the chassis/cabinet is grounded inside the unit.
On the backplane of the amp do you see an external Ground (i.e. GND) connector? Using fingers on two hands, try holding the GND connector and touch another metal part on the cabinet housing. Does the hum stop? If so, unscrew and remove the cabinet from the main chassis (carefully) and, then, simply put it back together again. If that doesn't work, take a short wire and connect one end to GND and the other to any metal cabinet screw. That should only be considered a temporary workaround until you can get Justin to fix the problem permanently.
KenB
post-1471027
Post #27 of 29
agile_one
忍者
DIY=Do It Yourself
PCB=Printed Circuit Board
GND=Ground
post-1471156
Post #28 of 29
spritzer
Well if the buzzing is in the headphone it could be a damaged transducer or something stuck to it that is creating a short.
post-1489391
Post #29 of 29
barilie
I now see a bit more clear in this problem! I opened the amp and saw that the wire from the +580V connector wasn't tight. So I screwed down that wire and then the hum didn't stop anymore. Quote:
No, but it stopped when I hold the +580V connector (on the bias supply board) with my electrical screwdriver (you know, with a light in it...) and simultaneously touched the cabinet housing. Quote:
In this case, should this work also?
How can I solv this problem?
