charliex
- Nov 28, 2008
Hi - I don't know if I have the right thread, but I believe it may be a computer audio issue. I have connected my computer sound to a Cambridge Audio DacMagic DAC - so all sourced information goes through the DAC therefore bypassing the onboard computer soundcard.
I have been successfully running my dynamic setup through a Little Dot MK III amp with no problems. Recently I puchased two separate STAX setups - a Stax SR-5 / SRD-6 combo and a Stax SRX Mark 3 / SRD -7 combo. I hooked up both energizers correctly to a Technics SA-410 New Class A Receiver, one to the main speaker terminals and the other to the auxillary speaker terminals, and ran RCA connects from the Aux Out to the DacMagic. For several weeks everything worked fine as I switched back and forth between the dynamic setup and the electrostatic setup - it was simply a matter of putting the appropriate RCA interconnect through the DacMagic.
Here's the problem - a few days ago the Stax Energizer / Technics SA-410 stopped working and all I can to operate is the dynamic setup. When running the stax setup it appears that the music is there and being received, but I do not get any sound through the headphones. My computer sound settings say, "Speakers C-Media USB Headphone Set Working". I have tried varios setups and to no avail, all I get is the dynamic setup to work - can anyone help me solve this dilemms - I think it must be some computer software setup, but I am not sure.
