protoss
- Mar 21, 2017
One thing is sure, it is more difficult to buy a very good dac than a very good amplifier, or a very good speakers, or a very good headphones, at a low cost; I know it for sure because that is my experience... I succeed but by luck and extensive studies, with a search without end for 7 years...
By a "very good dac" I means a dac that you will perceive trough your system without real defect, and only and always a natural sounding timbre in instrument and vocals...At the price that this dac ( Starting Point Systems NOS dac tda1543) sells used or new, upgrading it has no appeal for me at all...
Some people has said that it lack details, but in all my tweaking modification and upgrade no lack of details were experienced, except caused by other part of my system, or with my room, or with the lack of vibrations controls,or with the interference from the electrical grid...This dac gives only details integrated in musical coherence, I listen to the cd " jazz at the pawnshop" that a reviewer use for a review of a dac with a price so high that I dare not to mention it here; and all the qualities that this reviewer said about this cd to evaluate this high price dac, I had the impressions to listen to the same qualities with my low cost dac...I dont say that my dac equal the other one, I only say that the difference in price are so great and the difference in sound probably way more lower, then upgrading my dac seems impossible for me and I would not want it even with the money in my pocket...And I dont say all that to depreciate high end quality of other piece of audio, I say all that because sometimes miracles happen, and something high-end is sold at cheap price...Newcomers beware !
I know nothing in engineering but if you open this dac you will see with your eyes how simple and minimalistic it is in design, compare it for example with other 1543 chip implementation, simplicity and minimalistic design has a sound counterpart : less noise.... And probably in this direction the internal battery between the dac proper and an external power supply is a good idea too...Ok I apologize for my rant now and wish the best to all of you...
Hows the sound without the batteries?
