skwoodwiva
Same but 3 on my sony cans
Sorry man it seems all head games. ..
iso tried out this mod, krk woofer, Fluke 287, 3oz gel ball dropped from fixed hight. Etc etc
Pic lost when phone died.
Results nadda. 3 x the magnet size w/ proper neos, or a 3 magnet set up with idenical krk magnets.
Not a bit of peak recorded mv ac or dc noticed.
It was like .3 v no matter what. ..
I abused the driver so much I need to reform the coil form , I bent it, @amn it.
My two cents anyway.Just because you didn't measure any change in the voltage doesn't mean the mod is useless. I tried it on 4 different headphones. I noticed differences in two of them and not so much in the other 2.
The changes are pretty subtle and I think the main reason I was able to detect the difference in 2 of them is because those are the ones I have the most headtime with and listen to the most. I'm really familiar with how my 9500s reproduced sound without the additional magnets, and I do notice a difference.
It's not a drastic mod that will knock your socks off, but it took them up a notch in terms of listening enjoyment. I don't find myself reaching for my Fidelio L2s nearly as much as I used to because I find myself leaving on the 9500s for more types of music. I feel like the mod brought the sq closer to my Fidelios and kind of shelved my Superlux HD681 because they aren't on the same level now. I used to like 681s for when I wanted a bright/spare/clean kexcursionuseriond of sound with similar soundstage....they seemed more detailed than the 9500s, but that advantage is gone now, the 9500s are just BETTER in everything but the depth of the bass.
Now I need to get my hands on some sorbothane and see if I can get a little more bass out of my 9500s....
what does that even mean??My two cents anyway.
Bass? The ball must have done a very low excursion
If there were a flux density improvment then (at low freq) then the ball drop would have indeed been in the sweet spot you refer to.what does that even mean??
Yeah, I like speaking gibberish too, it's fun. Thanks for your two cents and hot takes.If there were a flux density improvment then (at low freq) then the ball drop would have indeed been in the sweet spot you refer to.
Again just my take. ...
Another potential benefit, at least in theory, is that stacking magnets might turn headphones into slightly easier loads for amps... at least high-impedance headphones. By theoretically making the drivers work more efficiently, the bar for amping requirements/horse power is lowered.
Just speculation on my part. Proper measurements would have to be carried out to be sure.
But I'm not entirely sure of this because, on the other hand, the stronger the magnets stacked on my HP, the more I feel the need to increase the volume...
The sound improves yet I feel compelled to increase the volume dial on the amp... anyone else has experienced this?
Hmm, do you mean that in your experiments the drivers literally stopped working (made no sound or sounded distorted in some way) or they still reproduced sound but came off as extremely overdamped? How many magnets or how big/strong are you talking about exactly? Are you sure you didn't somehow block some vent or restrict airflow?
I can see it getting to the point of sounding overdamped, but I can't imagine it stopping working due to magnets...
In any case, this lowered volume effect I hear on my headphone already happens with the 1st magnet. Successive magnets add cumulatively to the effect. While I managed to go overkill to the point of making it sound somewhat overdamped, it never reached a point where it just stopped working. Instead, it reached a point where more magnets simply had no further effect.
I should mention that I don't necessarily think of this lowered volume effect as a problem. It's only a very slight difference and it could be a direct consequence of the fact that the sound is cleaner with less distortion or faster decay. I'm just wondering about the relationship between the effects of stacking magnets and amping requirements because I have reasons to believe that magnets can affect the impedance curve of a headphone..
