KenW
- Jan 17, 2004
Got my Squeezebox today. Yeah, paid the $50 more for black. Okay, okay, it's nuts but I LOVE the black. Still got the $20 discount so it wasn't so bad. Setup wasn't exactly as I'd planned due to some rather unforeseen complications with various parts of my rig and home network so bear with this long winded description of the journey.
Right off the bat, this little jewel was bigger and more solid than I anticipated. Setup didn't go exactly as I'd planned though. As I mentioned, I also was throwing a Slingbox into my home network and that was a bit more challenging than I figured. Completely forgot that I had the electrician put the different levels of my home on separate circuits which made locating the Slinglink contrary to my original plans as it uses the power lines to enhance connectability/signal. Once I got the IP, ports, firewalls, etc taken care of, I then turned my attention to the SB3. Setup went well with no hangups at all. Just another round of tweaking the IP, ports and such.
After it was all tied together, I connected the SB3 to my Opus 21 to give it a run. My personal preference is to max the volume/output on both the Opus and SB3 and control the listening volume via my amp. Unfortunately, my Opus would not allow me to go into the setup menu as per the manual. After pulling my hair out, I took tkams advice and shot an email off to Resolutions tech support. They were quick with the reply that they'd changed the buttons used to enter that setup menu recently and the manual hadn't been brought up to speed yet. Once I got that info, I took care of my volume preset and I was off and running.
The SB3 is one fine source to be sure, and I was very impressed by it running through the coax of the Opus. Honestly, it was much closer to the Opus spinning discs than I'd dared hope for! The convenience might keep listening to CD's relegated to critical listening sessions. Well, that might be an overstatement. The Opus is one mighty sweet source and for the first time, it has me seriously considering a sale of the 555ES and Stello. It's truly special for the money spent. The question/temptation I'm now facing is about modding this player. I'll probably spend a good bit of time really getting to know it, but I'm pretty sure that my curiousity will eventually get the best of me and the mods will come. Til then I can recommend the SB3/Opus with a great deal of enthusiasm. I see a couple more SB3's in my future. What a great little device. The hype is well deserved. Dimitris, you're gonna love it.
Originally Posted by Dimitris /img/forum/go_quote.gif Yes looks like the all black SB3 is more attractive. Oh well for $50 I can put up with the duo-color! ![]() ![]() |
