Speaker amps for headphones
Sep 19, 2021 at 6:12 AM Post #3,691 of 3,772
FooFighter
Germany
Anyone?
Hi chaps
My friend @ErichA is about to receive my Forzaaudioworks Speaker TAPs.
His goal was trying these on his Mcintosh MA 252 for driving Susvaras.
Now as we both are kind of noobs regarding amplification technicalities we re seeking advice for this setup.
I heard that driving speaker TAPs out of tube amps isn't a good idea without resistors?
Does this apply to the described setup?
a) What shall we add to get it running without damage?
b) better use an adapter box like the one just posted before?
Cheers
Anyone?
Sep 19, 2021 at 10:44 AM Post #3,692 of 3,772
number1sixerfan
Cali
Anyone?
Anyone?
I'll let someone more technical jump in, but yes, I would use a resistor box with a tube amp, it's widely accepted that there's risk with using headphones with tube amps directly. I use Raal's interface box with really good results.
Sep 21, 2021 at 12:01 PM Post #3,693 of 3,772
Sandro Sena
Recife - Brasil
Hi,
do you use Raal's interface box as a way to connect conventional headphones to your speaker amplifier?
Sep 21, 2021 at 1:19 PM Post #3,694 of 3,772
Sandro Sena
Recife - Brasil
I ask you because I would like to use it in the same way, but I am unsure about the technical feasibility of such a use. If it is possible it would be great, without the need to look for and buy a good resistor box.
Sep 21, 2021 at 1:39 PM Post #3,695 of 3,772
ThanatosVI
Germany
I asked the manufacturer and he didn't recommend the use of the Interface Box for normal headphones.
The reason is because the Interface Box has baffle step compensation. It will alter the frequency response of other Headphones.
Sep 21, 2021 at 1:47 PM Post #3,696 of 3,772
DuncanDirkDick
Germany
Anyone?
Anyone?
You shouldn't run a tube amp without a load connected. If you can't guarantee that, usually a shunt resistor is used. AFAIK Mcintosh MA 252 is a SS with tube preamp, so you should be fine.
Sep 21, 2021 at 2:08 PM Post #3,697 of 3,772
FooFighter
Germany
Thx, you are right, I wasn't even aware of that design.
So if tube amp is used only as preamp, there shouldn't be any risk really as only the amp directly connected to the speaker TAPs matters?
Sep 21, 2021 at 2:13 PM Post #3,698 of 3,772
DuncanDirkDick
Germany
Usually, yes.
Sep 21, 2021 at 2:57 PM Post #3,699 of 3,772
Articnoise
Sweden
Correct.
Sep 21, 2021 at 2:59 PM Post #3,700 of 3,772
FooFighter
Germany
Sep 21, 2021 at 3:41 PM Post #3,701 of 3,772
Sandro Sena
Recife - Brasil
Thank you!
Sep 21, 2021 at 3:53 PM Post #3,702 of 3,772
number1sixerfan
Cali
Hi,
Yes, I use with regular headphones. I guess I could lug my marantz amp back into my listening room to compare with and without the interface, but I haven't noticed anything off with using the Raal box with the TC or the Susvara. I've pretty much landed on it and the EVO 400 as my main amp for both. But it's good info to have and eventually I guess I'll compare and report back.
Sep 21, 2021 at 4:28 PM Post #3,703 of 3,772
Sandro Sena
Recife - Brasil
Thx!
Sep 21, 2021 at 4:40 PM Post #3,704 of 3,772
deafenears
N/A
I guess that's going to change with the upcoming release of the RAAL circumaural SR1a - interface boxes without, or a switch to disable, the baffle step compensation.
