Sound card with amp for hd590s?
Jul 19, 2009 at 5:57 AM Thread Starter Post #1 of 9
b81434
Ok so i have become fed up with my m-audio revolution sound card due to the drivers/software being crap but i digress. I am looking for a good card that can also drive my hd580s. I got a cmoy amp a year back and it just didnt give me what i wanted. my perfect solution would be a sound card that can really drive my 580s. I have been reading about the ASUS Xonar cards and they sound like what i am looking for but part of me wonders if they can really drive the 580s. Mostly i listen to music and game at the same time.
I am open to any card or any amp but i dont really want to spend more than 250. I have read a lot about some of the options out there but most of them are out of my price range like the E-MU 404....
Jul 19, 2009 at 5:50 PM Post #3 of 9
look for something external with a proper amp and external power supply, most internal cards are limited due to the max power draw of a pci bus,
Jul 19, 2009 at 7:04 PM Post #4 of 9
Yea, definitely look for something external. I have a xonar dx soundcard, and I can't even pump the volume to 100% or else the volume starts fluctuating (I don't know exactly how to describe it, but basically it sounds like it's struggling to get power). I'm currently running my 580s out of a pimeta amp and it sounds decent, for $250 you should be able to find an amp that does much better.
Jul 20, 2009 at 4:04 AM Post #5 of 9
Incidentally, you might want to change your thread title...the hd580 and hd590 are totally different 'phones, and I think the 580 would probably pique more people's interest.
That said, yeah, I bet you're going to need a DAC (external sound card...they work better than the internal kind) and amp for the 580s. Being a beginner, getting an amp/DAC combo unit would probably be the easier way to go. Check out the HiFiMan EF2; FWIR, it's a good deal, and I remember a couple of very positive reviews (I recall headphoneaddict being quite taken with it).
EDIT: The EF2 costs about $210 shipped, so it's in your price range. No other non-DIY things within your budget leaped to mind, but that's probably me being slow.
Jul 20, 2009 at 3:59 PM Post #6 of 9
If you're gaming DAC isn't the way to go. X-FI Forte for more audiophile would be good as long as it supports all the stuff that my X-Fi Titanium does. It should since it has an X-FI dsp and 64mb of X-RAM. Should be a good card... but you may as well just buy them.
And that will be hassle-free for the most part. Only issues is, when you change modes between entertainment/game/creation it can sometimes cause flickering that requires a reboot. Otherwise it's pretty solid.
Jul 20, 2009 at 9:26 PM Post #7 of 9
Not sure how much more power it takes to run HD590's over AD700's, but I have the lower end xonar and it drives my AD700's easily, I usually have my volume below 50%. Driver wise there is nothing better.
Jul 20, 2009 at 11:13 PM Post #8 of 9
The AD700 has an impedance of 32 ohms. The 580's have an impedance of 300 ohms.
If I'm doing this right, that means the Sennheisers need a lot more voltage..
Jul 21, 2009 at 2:56 AM Post #9 of 9
Asus Xonar Essence STX or upcoming ST, can power 600ohm phones, there's 3 settings in the software, when I had the STX I used the lowest setting because I only had HD555 then, I didn't have my HD600 (there was a note saying be careful for the settings if you don't have the right ohm headphone).
External DAC+AMP also works, I am running optical out from my sound card to my external and it has been awesome. I don't use my X-Fi stuff but if I wish to I definitely could, best for both worlds.
