Sound Card or DAC / $600
Jan 16, 2006 at 4:35 AM Thread Starter Post #1 of 24
Arnoldhasmail
Who makes the best sound card in the $600 and down price range?
Internal/External...
Or do you just buy a good card with digital out and buy a dac?
Opinions...
Jan 16, 2006 at 7:06 AM Post #2 of 24
Malus
With that much money to spend, a good DAC and a soundcard with good digital out will probably be your best bet.
Jan 16, 2006 at 7:16 AM Post #3 of 24
grandenigma1
Member of the Trade:Enigma Audio
The more popular soundcards around here are the AV710, 0404 and 1212m. As for DACs you have a few options under $600. The CI Audio VDA2 or VDA1/VAC1 if you can find one (actually there is one in the FS right now that I would seriously consider picking up), Scott Nixon TubeDac+, Headroom MicroDac, and a few Chinese DIY types that are quite good.
I use to have a AV710 > VDA1/VAC and absolutely loved the pair!
Jan 16, 2006 at 1:08 PM Post #4 of 24
gordolindsay
I'd also go the cheap soundcard->external DAC route. In that price range, you could find a used Ack Dack! on audiogon.com or something. THat would be a mighty fine setup.
Jan 16, 2006 at 2:13 PM Post #5 of 24
jiiteepee
Opinions...
What for --> Which would be the path from PC to your ears you have planned and, which would be the he final "element" on that path (headphones or/and stereo speakers or multichannel speaker system)?
jiitee
Jan 16, 2006 at 3:32 PM Post #8 of 24
Elephas
For US$600 a Chaintech AV710 or E-MU 0404 paired with the CEC DA53 would be a good combination. Or, skip the soundcard and just use its USB input plus the USB ASIO driver from usb-audio.com.
It has balanced XLR outputs too, for the inevitable upgrade to balanced amps.
Jan 16, 2006 at 5:52 PM Post #9 of 24
Ypoknons
Honestly I don't see why you have to get a soundcard and a DAC when you have USB enabled DAC's - I'd love to see some of the arguements in favor of this.
Jan 16, 2006 at 6:23 PM Post #10 of 24
gordolindsay
I'm not gonna argue against this. BUT, by limiting yourself to use just USB and no soundcard, you are missing out on some of the great DAC's. But yes, a USB DAC would be the easiest way to go.
Jan 16, 2006 at 6:27 PM Post #11 of 24
dmb367
A cheap soundcard with digital out can be paired with any external DAC, allowing you to tailor your system to you preferences.
And many external DAC's will out-perform any soundcard
Jan 16, 2006 at 7:06 PM Post #12 of 24
Medikit
Can someone explain to me how you hook up to a DAC, do you use digital in? So if you go digital from your cheap soundcard to a high end DAC then it totally ignores the soundcard? I don't think I really understand how DAC's work and what kind of source they need. Where is a good place for me to study this?
Jan 16, 2006 at 7:40 PM Post #13 of 24
Ypoknons
Ah. Hence the popularity of the AV710.
Jan 16, 2006 at 8:26 PM Post #15 of 24
dmb367
The reason for a soundcard is to get a digital signal from your computer. If you had a powerbook, for example, then you wouldn't need a soundcard because powerbooks already have digital line-out's. That digital line is the input to the DAC, and the output is analog RCA's.
