Sony's DSD-capable PHA-2 portable headphone amp/DAC
- Thread starter shigzeo
- Aug 15, 2011
I did a search here and either I didn't read carefully but I don't recall seeing any real life results of the battery life of PHA-2's. Are they as short as the PHA-1's or has Sony increased the operational life of the PHA-2 per charge?
Anak... think I was getting about 18-20hrs out of a charge using RB-lossless but can't say for certain.... think it's about 10-12hrs using Hi-Res.
- Aug 15, 2011
On the PHA-2!?!? 2 digit hours? That's a vast improvement. Thanks.
f198
- Aug 30, 2013
In what usage scenario ? On computer/iOS device/walkman ? As amp or dac+amp ? What impedance has the headphones used ? Thanks.
for the main Sony F887 & PHA-2 (headphone amp) & PC & PHA-2 (DAC/Amp)... both mainly with Kef M500's.
I was using as a mixture on a single charge over several days (Atrac & WAV files)... I never tested with Hi-Res files as I only own one.
delancyst
- Mar 26, 2009
i have been looking for usb powered dac/amps that can be used on my desktop to run ciems.
is this a good choice?
BillsonChang007
That boils down to, are you planning to use it with your iDevice as well?
delancyst
- Mar 26, 2009
Not necessary to use with an iDevice.
I'm looking primary to get an external dac/amp to compliment the Schiit Lyr + LCD-2.2 setup on my desktop since Lyr isn't a good candidate to drive iems.
PHA-2 looks small enough to be transportable which is a bonus, but im more interested if it is solely usb powered.
I was looking at the Apex Glacier and ALO Pan Am but the Glacier seems to have generally a bright signature (i love warm sigs)
And the Pan Am was out of the question coz it needs separate power supply.
Was looking at the RSA Predator as well, but that too needs a separate power supply.
Do you know any other dac/amps that are usb-powered?
Thanks!
BillsonChang007
Thanks!
I am not sure if Sony has decided to lower their PHA output impedance, but the first version's output impedance may be way too high for IEM. There's the E17 worth looking into or Leckerton amps/DAC
Billson
delancyst
- Mar 26, 2009
Interesting. Thanks for pointing out the Impedance issue.
Hope to see someone get their hands on one to review.
I see the PHA-1 had 10ohms, cant really find the OI specs of the PHA-2.
- Apr 28, 2007
The link I quoted in this earlier post used to work, and it provided very detailed specs, but Sony seems to have taken that page down:
http://www.head-fi.org/t/680208/sonys-dsd-capable-pha-2-portable-headphone-amp-dac/240#post_9949418
Mike
delancyst
- Mar 26, 2009
Mike
Thanks for the link zilch0md.
So, what I get from that post, is that the PHA-2 is weak for headphones like the LCD-2 but it doesn't really say if its output impedance is suitable for sensitive IEMs?
- Apr 28, 2007
What I get from that post is that the PHA-2 is weak for headphones like the LCD-2 but it doesn't really say if its output impedance is suitable for sensitive IEMs?
Yes, I regret not looking into that point when that page with detailed specs was still available. I have no idea what the output impedance is for the PHA-2.
I don't even know for sure if output impedance was included in that table of specs from which I only quoted output power.
Today, I've looked for specs, but like you, can't find anything on output impedance.
Mike
