MRSallee: From post 977
If building an EQ off the graph, I recommend using this graph instead: https://squig.link/?share=Super_Review_Target,Sony_WF-1000XM4
Based on the above frequency response (green 65% volume) graph line, here is the calculated Parametric and Fixed Band EQs for Harman In Ear Target 2019v2.
# Sony WF-1000XM4
See [usage instructions](https://github.com/jaakkopasanen/AutoEq#usage) for more options and info.
### Parametric EQs
In case of using parametric equalizer, apply preamp of **-4.4dB** and build filters manually
with these parameters. The first 5 filters can be used independently.
When using independent subset of filters, apply preamp of **-6.8 dB**.
| Type | Fc | Q | Gain |
| Peaking | 42 Hz | 1.16 | -2.8 dB |
| Peaking | 210 Hz | 0.86 | -3.8 dB |
| Peaking | 1373 Hz | 1.18 | 2.8 dB |
| Peaking | 2682 Hz | 1.18 | 3.8 dB |
| Peaking | 3943 Hz | 1.18 | 3.8 dB |
| Peaking | 1148 Hz | 0.26 | -3.3 dB |
| Peaking | 17528 Hz | 0.65 | -2.9 dB |
| Peaking | 18525 Hz | 1.95 | 1.8 dB |
| Peaking | 21263 Hz | 0.74 | -3.5 dB |
| Peaking | 21798 Hz | 0.7 | -4.2 dB |
### Fixed Band EQs
In case of using fixed band (also called graphic) equalizer, apply preamp of **-4.9dB**
(if available) and set gains manually with these parameters.
| Peaking | 31 Hz | 1.41 | -1.4 dB |
| Peaking | 62 Hz | 1.41 | -2.3 dB |
| Peaking | 125 Hz | 1.41 | -3.1 dB |
| Peaking | 250 Hz | 1.41 | -2.8 dB |
| Peaking | 500 Hz | 1.41 | -2.1 dB |
| Peaking | 1000 Hz | 1.41 | 0.3 dB |
| Peaking | 2000 Hz | 1.41 | 2.0 dB |
| Peaking | 4000 Hz | 1.41 | 4.2 dB |
| Peaking | 8000 Hz | 1.41 | 1.6 dB |
| Peaking | 16000 Hz | 1.41 | -5.6 dB |
### Graphs
# Sony WF-1000XM4
### Parametric EQs
### Fixed Band EQs
### Graphs
