Sony Walkman Tune (OEM Update)
Jul 1, 2021 at 5:41 AM Post #16 of 21
RobertP
thank you. I have a European model. is your tuning working? thank you
Yes. I don't see why not. I ran this tune countless times.
Jul 1, 2021 at 7:34 AM Post #19 of 21
nc8000
Kalundborg, Denmark
It will work on any model and you can change the region with the RockBox nwdest tool which also will remove the volume cap and enable high gain
Jul 1, 2021 at 4:49 PM Post #20 of 21
RobertP
the progress bar does not end
Eclipse is just a tune. It doesn't contain firmware file so the progress bar on your 1Z will end almost instantly. It's normal.
Aug 4, 2021 at 1:00 PM Post #21 of 21
RobertP
Eclipse R2 for NW-WM1Z >> Link
Please follow the included instructions!
Unlike other previous versions, This one is tuned with my new upgrade cable. The old cable makes everything sound thick and heavy. Also colored Mid a bit. So it's not an ideal for making tune.
