willr666
- Oct 3, 2010
Ok - I just got a M10 and this memory card (samsung evo sdxc - http://www.amazon.com/Samsung-Electronics-Adapter-MB-MP64DA-AM/dp/B00IVPU7AO/ref=pd_cp_pc_2)
Can I just drop the card in my macbook pro (2013) - format it as "MS file system" and use it in the recorder? It would seem that is implied at the end of this thread or do I need to us a specialized format utility. I used to us my d100 a lot and am running HEBs (DPA 4061???- they are about 12 years old) with the battery box into line in set at low/no limiter/no LPF/24bit48K. I'll be taping either front of stage or at the stacks for best sound/least crowd noise.
I can't do a test run with this at a real show as the concert is tomorrow nite, I'm anal, and want to make sure everything is set-up as completely as possible.
Thanks in advance,
Will
Thanks in advance,
Will
