Sony NWZ-ZX1 - 35th Walkman Anniversary model
Mar 6, 2014 at 8:13 PM Post #4,021 of 7,696
delancyst
Thanks for the links, very interesting.
I will drop superfi an email asking when they are expecting stock.
Waiting for Sony to reply to my email from a couple of days ago about when they expect stock too.
Out of interest what headphones are you all using with your ZX1?
Pondering whether I need some new ones to go with a ZX1 or my existing will suffice :D
Any headphones as long its not sensitive iems as you will hear a lot of hiss.
This dap is quite noisy.
Mar 6, 2014 at 8:58 PM Post #4,022 of 7,696
the hiss is too much for those with sensitive iems.
it can even be heard during quiet passages.
You've mentioned this twice already and either I'm just insensitive to hiss or I'm lucky but of the two ZX1's I've tried (one's mine, another bought to ship overseas for a friend) had no noticeable hiss. As first I thought you were responding to a post about PHA-2 but even for the PHA-2 I don't hear any hiss but that was demoed at a shop so I'm willing to accept that I didn't pay enough attention to the PHA-2.
For the ZX1 though if there's any hiss, it's way less than the early Rx Mk3's 'cos I don't hear any hiss with my ZX1.
Is there a possibility there's something wrong with your ZX1?
Mar 6, 2014 at 9:37 PM Post #4,023 of 7,696
delancyst
It is possible that I've gotten both the PHA-2 & ZX1 with issues (channel imbalance + hiss) :)
But listening on my Fitear, direct from ZX1, it does have noticeable hiss. If I listen from the PHA-2, it's dead silent - but you get slight imbalance below 9 o'clock.
Just helping to keep potential buyers out there informed to look out for these issues.
Mar 7, 2014 at 3:22 AM Post #4,024 of 7,696
kkcc
I had many issues with zx1 and hiss wasn't one of them. I don't recall any hiss on my Fitear tg334 or my JH13fp, which are both quite sensitive to hiss. I had not been able to test this in an absolutely quiet environment but find myself liking the black background. Similar with PHA2 I find it very clean also. Would you happen to be charging when you listen? I had DAP that has hiss only when charging.
Mar 7, 2014 at 4:23 AM Post #4,025 of 7,696
Apart from running outta capacity, what issues did you have with your ZX1?
Mar 7, 2014 at 4:45 AM Post #4,027 of 7,696
Vect
absolutely no hiss in this household using ZX1 with sensitive IEM's... same with F887 & PHA-2 no hiss whatsoever.
knock on wood here too, perhaps your IEMS are extremely sensitive or there might be an external noise source. I particularly used also the pha-2 as both a pc DAC and as a simple line out for my desk amplifier... It sounded better than my creative z soundcard (bass and highs far more refined) again, I failed to perceive any kind of noise.
Mar 7, 2014 at 6:32 AM Post #4,028 of 7,696
delancyst
I thought you may have hit a nail there, because I do listen to the ZX1 most of the time while having the USB connected to the PC.
However, I tried your suggestion, and unfortunately it did not fix the hissing issue.
I understand different people might have different hearing when it comes to tolerating the level of hiss.
So try this...
1) with the ZX1 turned on (but screen off) aka idle - wear your fones.
2) press the power button at the side to wake up the Lock screen.
3) you should hear a short burst of hiss that should be apparent enough in a quiet room.
4) the hissing does die down shortly after the initial burst, but it does persist throughout the usage of the DAP.
Although again, depending on your ears sensitivity, that level of noise floor might be negligible or unacceptable for some.
Mar 7, 2014 at 9:00 AM Post #4,033 of 7,696
mannp
Nice case 'Dignis Canas', where did you purchase it from if you dont mind me asking.
Sony support finally replied and said I can preorder but when you go through to order it says out of stock and you cannot order....I replied and said you cannot order, but today it seems they've fixed the site!
Is it s ripoff when you have to send the item back to japan with pricejapan? Not sure myself, I'm tempted .. just know what they did with my Xperia Ultra, ordered and then they started to do giveaways with the order that I missed!
Edit: I wanted to ask,
is the ZX1 firmware updateable like the Xperia phones
can you load the latest Walkman app from the Z2 onto it, or will that just detract from the experience
do all the apps go through the same output to the headphones or is there a specific hidef app for music playback?
Thanks for any feedback :)
Mar 7, 2014 at 9:05 AM Post #4,034 of 7,696
Chevalierr
Previously known as semajm85
i don't hear any hiss with my K10.....i did when i owned the 1070 thats why i sold it.
Mar 7, 2014 at 9:08 AM Post #4,035 of 7,696
Super Pang
UK
I've imported all sorts over the years and this seems a better deal than most. I'd rather have a UK warranty and better resale value than save £30-50. If the volume cap is taking the piss I'll just send it back.
