SONY NW-ZX500
Dec 20, 2019 at 11:24 AM Post #1,352 of 8,206
PointyFox
It's a good thing burn in doesn't affect measurement equipment! Factory calibrations would only be good for a few hours of use!
Dec 20, 2019 at 11:28 AM Post #1,353 of 8,206
graphidz
Well another way to know is if the engineers that made the DAP (like THE people that knows the ins and outs of the device) say you don't need to burn in, then you'll more than likely enough to not need any burn in.
Dec 20, 2019 at 11:32 AM Post #1,354 of 8,206
brokengundam
New York
Believe in burn in or not, Sony recommends it for each of the connections.
Dec 20, 2019 at 12:03 PM Post #1,355 of 8,206
purk
Only if the test is done on a much bigger sample size then sure. And even then, I have doubts that the changes found will be the make or break reason to get a DAP
Yes, you can also have different referencing points too. Like zx300, WM1A, and WM1Z....along with ZX100, and ZX2. Again, at the end it is all about a listening preference and the headphones you use.
Dec 20, 2019 at 12:07 PM Post #1,356 of 8,206
graphidz
Yeap. In a hobby where personal subjectivity matters in the end, I'd say "you do you" to them.
Well like I said earlier, I'll trust what the engineers say. If they recommend to do so, then it might be worth doing so.
Dec 20, 2019 at 2:23 PM Post #1,358 of 8,206
JanHoJan
Hong Kong
got mine ytd, so happy to go back to sony for my music
i mostly rip and play flac with the player
is it possible to sort the album order by release date(poweramp has this function)?
it bothers me a lot
btw the android system runs much more smoothly and reliable than players from fiio and hiby tht i owned
Dec 20, 2019 at 8:33 PM Post #1,359 of 8,206
osiris1
it bothers me a lot
you can sort by date you copied into folder, Newest to Oldest only
Dec 21, 2019 at 11:02 AM Post #1,364 of 8,206
ahossam
East Java
ZX507 is not an ideal player to use exclusively with music streaming services, the processing power is too weak to run the app, I primarily use Qobuz and its so slow.
