Having owned the ZX300 for over 6 months now, I'm still really enjoying it.
I've been using my Bang & Olufsen H8i with a 4.4mm cable, powered, with the Noise Canceling turned on. In passive mode the bass is too thin.
Can anyone recommend an alternative set of headphones for under £300 that will sound better? Or shall I stick with what I have?
Edit: Should have mentioned that I listen to Electronic and Classical, usually without vocal. Detail in the highs, depth in the bass.
