Sony NW-ZX300
Discussion in 'Portable Source Gear' started by riotgrrl, Jul 10, 2017.
428 429 430 431 432 433 434 435 436 437
439 440 441 442 443 444 445 446 447 448
  1. Hinomotocho
    High gain is said to have audio improvements over the low gain, more power driving it perhaps.
    alphanumerix1 likes this.
  2. superuser1
    i just want to know what high gain increases.. voltage or current or both? I was always bad at applied electronics and physics in school.
    kms108 likes this.
  3. kms108
    And battery:yum:
    superuser1 likes this.
  4. colonelkernel8
    Voltage. Current follows voltage, so the greater the voltage gain, the more current will be required to "sustain" the voltage. Because it's human that louder = better, it makes sense that the audio would sound better at a higher gain. There is no other benefit.
  5. Ghost2501
    I have the Nuraphone (AptX HD compatible).
    Sound is great.
  6. Ryokan
    That's what I've been wondering, high gain now off and volume around 70. Be interesting to see how long the battery lasts. :fingers_crossed:
    cthomas likes this.
  7. audioaudioaudio
    Post back on these High Gain battery tests - very interested to see the results.
    Not strictly on topic but as a lot of you (seems the majority) own a pair of the N3BPs, has any of you bought the standard 3.5mm cable to use it with non balanced sources? What's the cost / part number?
    One other question, any thoughts on the worth of the Sony MUC-M12SB1 - waste of money for any gains? Does the N3BP come with Sony MUC-M12NB1? I'm nearly certain, even vaguely remember reading it in this thread but can't seem to find it at the moment.
  8. cthomas
    Has anyone heard Sennheiser HD650 vs HD660s on ZX300 balanced? Wondering how much better (if at all) the HD660s is driven than the HD650 so I can decide if I wanna upgrade or just get a new balanced cable for my 650.
    I like the sound of my HD650 on SE but there's not enough volume. I've heard that the HD660s isn't actually that much easier to drive than the 650 despite being 150ohm compared to 300.
  9. colonelkernel8
    Assuming the actual listening volume is the same and you’re not simply listening twice as loud, the effect on the battery life will be very minimal, especially since this device is probably a class AB amp.
  10. Hanafuda
    I've read here a number of times the zx300 (and the WM1 series too afaik) is a class D digital amp.
    Now ask me what that means. ¯\_(ツ)_/¯ Little heat and improved battery life is all I remember reading about it, not what makes an amp belong to one class of architecture or another.
  11. colonelkernel8
    Well class D is a far cry from class A or class AB. It’s an entirely different architecture and one that indeed does vary its total consumed power fairly closely with output power (especially near its optimal output levels), so different volumes would affect battery life, but two different gain levels set to the same output volume are going to draw the same power no matter what.
  12. Mathieulh
    My HD650 sounds fantastic on balanced with the ZX300 as a source. SE does not supply enough power to drive it. I strongly suggest you invest in a balanced cable.
    cthomas likes this.
  13. colonelkernel8
    Just Sony MDR-1000X (originals) for me. I like them better than the Mk2s...better build quality IMO.
  14. Weaves
    I didn't know that the Oppo PM3 is naturally balanced. So i just got that and will order a balanced cable from surfcables.
    Thanks though
  15. BoomBox
    I haven't tried the HD660s, however on balanced the ZX300 has more than enough power for the HD6XX (HD650 in fancy shell) for me. They quite sing around the 85-95 mark. On max volume it's a bit too uncomfortable for me. High gain, that is.
