Sony NW-ZX300
Discussion in 'Portable Source Gear' started by riotgrrl, Jul 10, 2017.
291 292 293 294 295 296 297 298 299 300
302 303 304 305 306 307 308 309 310 311
  1. terrosa
    Try create a folder named MUSIC on your SD Card and move all your files to that folder
    Scubadevils and Hedonism like this.
  2. JerryHead
    Would you have a link to that? All I'm coming up with that on Amazon is the Apple Lightening to USB Camera Adapter.
  3. Scubadevils
    Yes that did it, thank you! Looks like a bottle of wine tonight and lots of music loading... can't remember the last time I've been this excited about a new item of electronics!
    abitdeef likes this.
  4. terrosa
    glad be able to help. and enjoy ya!
    Scubadevils likes this.
  5. psikey
  6. superuser1
    Managed to put the screen-guard on. Looks alright.. I am not a fan.
    kms108 likes this.
  7. ailean
    I've used the "Apple Lightning to USB 3 Camera Adapter" to do this, think there's only one version of the USB3 adapter.
    As mentioned it's a little bulky for mobile use but you can charge both devices while using it as a desktop/bag solution.
  8. abitdeef
    You might not be a fan superuser, but you're still cool! :) love the hydria spacefolk., and I think I'm going to try the ibasso, they still look too big for my ears but I can always send them back.
    I don't think I could ever cover up that beautiful screen myself.
    superuser1 likes this.
  9. Gosod
    What do you mean dial up? you mean sound processing software?
  10. JerryHead
    Wait a sec, one of the things I'm in the process of listing on eBay to pay off my ZX300 is my Oppo HA-2SE. Ironically, I think one of the accessories is a lightening to USB adapter. And I don't think it's bulky either. Maybe it can be purchased separately.
  11. Lord Mike
    I have both, and since picking up the ZX300, my WM1A has been sitting on the shelf.
    I know people always like to perceive a noticeable difference in sound to justify price difference, but between these two, negligible.
    Ginjo, abitdeef and larzy like this.
  12. psikey
    Don't think so. The OPPO is Apple certified not needing the Camera Connection Kit. The chip is inside it so the cable is just a dumb lightning to USB. There is an option on Penon audio which could be used with the WM-port adapter but never seen a straight WM-port to lightning cable with Apple chip.
  13. psikey
    The cost placebo makes you think it's got to be better! Tried both and no significant difference SQ so it's down to size, battery life, DAC support.
    My needs and cost goes to the ZX300 and 1A returned. The ZX300 is just the perfect size/shape with a quality build plus I can use with Tidal as a DAC to PC or phone. Upto 30hrs battery is plenty.
    The ZX300 sounds simply superb with my SE846's and Sony Kimber 4.4mm balanced cable. The HD660S sounds great too but still find the SE846 superior.
  14. JerryHead
    Just saw this. No, I only have like 3-4 hours on my balanced output (5 hrs on the SE). I now use the balanced output solely. Uncappped? Meaning, can I raise the volume to it's max setting? Yes, I purchased the Japanese version, and changed the language and I believe it already came with no volume limitation.
  15. Lord Mike
    My only quibble with the ZX300 is its combination of rounded edge and flat buttons make it hard to locate the correct controls when it's tucked away, whereas it was very easy with the WM1A.
    I'm sure it's just a matter of getting used to it. And the NWS20 remote solves a lot of those issues.
    Beninnzorjp likes this.
