Sony NW-ZX300
post-13851976
Post #2,746 of 11,402
Bepli
Germany
Germany
Sorry my typo, it's MQA, does the actual display indicate the files are MQA, as I have one MQA file, but does not show, but will play normally.
Yes in the album viewer or in the advanced details it will say MQA instead of FLAC
Reactions: kms108
post-13851995
Post #2,747 of 11,402
kms108
It seems like i'm not getting it, alright it doesn't really matter, i'll just listen to it as normal.:yum:
post-13852198
Post #2,748 of 11,402
highning
I think this has already been discussed in some way but I was planning to buy a ZX300 along with a Sennheiser HD 660 S for christmas. The 660s come with a 4.4 mm balanced cable.
On the european sony site I have read the following stats:
Headphone Out (Stereo mini-jack)
MAXIMUM POWER OUTPUT (JEITA 16Ω/MW)
1,6-4,2 mW
Headphone Out (Balanced standard-jack)
MPEG4
1,6-4,2 mW
while sony.com says this:
50 mW + 50 mW (High Gain)
MPEG4
200 mW + 200 mW (High Gain)
Is there really such a significant difference? Will the ZX300 be able to drive the 660s at all?
Thanks in advance!
post-13852403
Post #2,749 of 11,402
kms108
It seems like the Japanese version sold in amazon has dropped there prices, and also it looks like the official tourist version might not be released.
post-13852454
Post #2,750 of 11,402
JerryHead
SoCal (North America)
First impressions (on the look and feel side) : very beautiful device. I like the mate screen and I don't think that I'll put a screen protector on it.
I thought that I didn't need a case but I'm afraid that someday, the unit will fall on the ground (I always pay attention but like the bumper sticker says '**** happens'.
For me, the most beautiful audio player that I got was Sony Walkman WM-DD9.
http://www.walkman-archive.com/wa/project/sony-wm-dd9/#!prettyPhoto[gallery]/1/
I had a similar one! I too loved those! Got my first in the early 80s I believe..
post-13852458
Post #2,751 of 11,402
Whitigir
The next most beautiful one will be WM1Z :D
post-13852460
Post #2,752 of 11,402
Bepli
Germany
Germany
1,6-4,2 mW
MPEG4
1,6-4,2 mW
MPEG4
Thanks in advance!
Yes there is a difference between capped and uncapped! Tho its not that huge but I would recommend to just remove the cap. Its very easy to remove and is done in less than 5 minutes. Also the hardware for all ZX300 is the same so if you uncap your player you will have the complete power like all other uncapped units. Also the output on the European site is wrong, I informed the Sony support already but that numbers arent the realy output numbers of the capped version! Also dont worry about the warranty, uncapping your unit wont cause any problems with the Sony support! I have a friends who had to sent in his uncapped A30 and they didnt care about it (probably didnt even check it).
post-13852461
Post #2,753 of 11,402
Bepli
Germany
Germany
I personally like the ZX300 way more since its rather sleek looking because its one form and doesnt have the output sockets a bit on the outside (I hope you know what I mean).
post-13852464
Post #2,754 of 11,402
Whitigir
Ah, definitely, the Walkman Ears, and that is what I call it :D
Reactions: Bepli
post-13852466
Post #2,755 of 11,402
JerryHead
For those with experience with the Shure SE846 iems: I've never used these with a balanced connection/cable. Should I replace the current "sleeve" with the balanced sleeve, instead of the standard one which I believe I have on there now? Will doing so optimize the sound? Thanks.
post-13852474
Post #2,756 of 11,402
Bepli
Germany
Germany
The balanced output does sound better and puts out more power so it might sound a bit different. Tho it might be that the SE846 might not sound very different. Best would be to try it and if you like sound alot more keep the cable.
post-13852477
Post #2,757 of 11,402
kms108
One thing about the ZX300, most glass screen protector on the market won't fit, as the edge is slightly curved, you will get air gaps along the rim, most glass protector is made to the right size which runs right along the edge.
Reactions: Whitigir
post-13852490
Post #2,758 of 11,402
JerryHead
Why wouldn't the SE846 in the balanced output not sound very different? (I bought these iems believing that they were fairly high-end)?
post-13852497
Post #2,759 of 11,402
Whitigir
Well, High-end doesn’t mean High-performances to everything :D . High-end only means “high-maintenance”, or simply put.....more expensive to get it to perform right :D.
You don’t date Super Models with nickels and pennies my man
In this case, the synergies with your 846 and the Zx300, and maybe the power output differences or impedance on both SE and Balances maybe differences....or the cables..... Most of the time it is positive, but sometime it could be negative. You just have to try it out and find out
post-13852518
Post #2,760 of 11,402
JerryHead
Okay, gotcha, understood. Out of curiosity, which iems are people finding pair very well with the ZX300??
Users Who Are Viewing This Thread (Users: 2, Guests: 9)
