Sony NW-ZX300
post-13846887
Post #2,657 of 11,402
NoMythsAudio
Miami
Miami
post-13846913
Post #2,658 of 11,402
Redcarmoose
Reactions: NoMythsAudio
post-13846924
Post #2,659 of 11,402
Redcarmoose
Are you using 4.4mm jack on the zx300? Is that a 3.5 to 4.4 adapter?
Just click on the Mee Company Link I provided in the original post.
It's a MMCX cable, a balanced 2.5mm to 4.4mm. Or 2.5mm to 3.5mm balanced or .........2.5 to 3.5 single-ended.
It works with the zx300, though I went to buy a zx300 and heard one, but it was only a demo so I jumped to a NW-WM 1Z. :wink:
post-13846937
Post #2,660 of 11,402
khestoi
I am new to this balanced stuff. I am actually planning on getting a brainwavz b400. Its stock balanced cable should be compatible with the zx300 right? Or do i need any other adapters?
post-13846940
Post #2,661 of 11,402
Redcarmoose
How is the cable? soft and supple? and the SQ. Some impressions would be most welcome.
I like the cable, and for $100 it's pretty cool. Though the wise will maybe make their own or wait till Sony has something that cost less than $260? I don't like adapters and as you can see it's 2.5mm to 4.4mm then to the NW-WM 1Z, but the Sony XBA-Z5 is mind-blowing with Pentaconn 4.4 balanced. Huge step up in SQ.
https://www.amazon.com/Sony-MUC-M12...coding=UTF8&psc=1&refRID=RAEWH39ET6AG9AT8DFVN
I was simply too curious to wait. Just amazing-end-game sound.
The cable is soft and is perfect size, though my issue is I can never leave the house, as I would need to heat-shrink over-ear support. The wires dangle. lol
Reactions: superuser1
post-13847067
Post #2,662 of 11,402
SoLame
El Rancho PR, LA-CA
El Rancho PR, LA-CA
You need an adapter. Your balanced cable is terminated with 2.5mm plug. You need to convert it to 4.4mm to use with ZX300.
post-13847117
Post #2,663 of 11,402
khestoi
I see. Let me see if there are cables with 4.4mm balanced terminal...
God! These wires are expensive!
post-13847441
Post #2,664 of 11,402
kms108
The new F/W has been out for a while now, does anyone have a more detailed information with it installed, any ups and down with the update.
Thanks
post-13847548
Post #2,665 of 11,402
Brice d’Oliveira
France
France
Hello guys p’ease Help ^^
My zx300 is in startup bootloop... even after resetting it it doesn’t start... it stay on the wave for 3/5 min then restart again and again...
Any idea is welcome
post-13847562
Post #2,666 of 11,402
kms108
Any idea is welcome
have you tried to reflash a F/W on top.
post-13847564
Post #2,667 of 11,402
Brice d’Oliveira
France
France
Yes but I just have my mac with me and after downloading the update 2 times it says me it’s corrupted...
But yes i’ll Try with a pc as soon as I can...
So strange ... maybe the new update...
post-13847571
Post #2,668 of 11,402
musicdragoon
Thanks
Just updated my JP ZX300 with the windows direct update exe, I am with win10 and the whole process is smooth and fast, just spend a few minutes from download to update complete. And after update it will take a bit time for ZX300 to rebuild the database, after that you will be able to use aptxHD (which I have no use), and seems the sound quality improved a bit, seems like with the new firmware the clarity increased and sounds more open to my ears. But I really don’t know if this change is really from this firmware or from a few more hours ageing, as my ZX300 is still within 100+ hours stage :wink:
post-13847611
Post #2,669 of 11,402
musicdragoon
Do your ZX300 have left 200MB internal space for the update? I just run the windows version and its a smooth process.
post-13847717
Post #2,670 of 11,402
Brice d’Oliveira
France
France
ok, so i've just downloaded the Pc update and trying on the Pc i've used before to update and change region (so my device is recognize by it).
the update screen appears, the update begin and on the screen off the device and go until the end, on my computer it says update is ok and device too but no luck... the zx300 doesn't start...
and it start again and again... stuck on the wave and reboot...
oh, and yes i have 200mb to make the update.
I think i've kill my zx300...
Users Who Are Viewing This Thread (Users: 0, Guests: 6)
